DELL LAPTOP AUDIO INPUT
Crazi_chic
im using dell laptop im stuck its saying audio driver no device is enabled coz its not under garantee dell arnt helpful any advice
I moved this topic to General Laptop discussion.  If you are truly having issues you could try a few things.
Search for the Dell model number online and find the correct drivers for the laptop.  Dell is usually good about having this available.
In Windows go to Device Manager and find the audio device. Delete it, reboot, see if windows will re-add it correctly.
Try Dell again. Sometimes calling back or using their online support works the second time around.
Good luck.
