CAUTION: Orbi's Wifi Guest Network does not really isolate guests from main network
itGeeks
As good as Netgear Orbi may be and the fact it retains its #1 spot does not excuse them from the privacy that guest network should have, This is over a one year old problem so it looks like it will never be fixed. I know 1st hand that customers have spoken to Netgear support on the phone then the issue goes silent with no fix. I tested Orbi just over a year ago and I was blown away with the coverage and performance but advertising and supporting a guest network that is not isolated from the main network is unexceptionable, In fact even in my own testing I contacted Netgear over a year ago and asked them why did the guest network get an IP in the same range as the main network and that went unanswered. buyer beware. You can read the complaints here
Odd. I have guest isolation enabled and my guest WiFi network isn’t able to access the LAN.
