Gulftown
Microserver Gen8 chassis fan upgrade.
Gulftown
1 hour ago, RobWu said:
almost noise-less
Can't quite imagine noiseless microserver stock fan setup. My microserver sounds like jet engine with the stock fan and I don't know the way to make it sound not so loud.
How could you acheive this result?
RobWu
Nothing really. It was always very quiet, only had the 'chirping crisis' just once.
It is only very loud when I restart the server, but as soon as the boot sequence is finished, the fan throttles down to low noise levels.
Sorry, but that's it. I just recall a driver pack, or update pack, for the server once had the fan running faster than normal. But that was fixed quite quickly. No idea how, when or where to find this atm. ;)
Maybe a search on the forum might help out.
rob
Gulftown
What CPU and RAID controller (and if b120i, what mode, AHCI or RAID) do you use?
I've got E3-1260L and P222 PCIE RAID that affects heat and fan speed for sure.
Edited by Gulftown
RobWu
G1610T & b120i in RAID mode. Nothing fancy ;)
Gulftown
Celeron produces not so much heat and b120i also known to increase fan speed in AHCI mode but be ok in RAID mode.
One day you still need to be ready for fan replacement...
Edited by Gulftown
fury
I ended up buying a HP fan with the 6 pin connector, just to cut the connector off and solder it onto a 4 pin PWN fan as per SilentPCReview.
Made a world of difference without worrying about creating a controller.
Has been running for many years without fault.
Gulftown
In fact, Mihai's scheme is really bad as Microserver is going into loop RD lock detection. If you open the SPC link you will be able to clearly read the datasheet prohibition to do so ).
I would like to find some time to make some measurements with oscilloscope before putting everything together. But if you think I slould hurry I can create a topic with all the information I found regarding this topic.
Gulftown
12 hours ago, fury said:
4 pin PWN fan
Would you be so kind to tell me the manufacturer and model?
fury
It's a Noctua 120mm fan - NFP12
Looks like it's not PWM but is only 1200RPM and quiet running flat out.
Now I think about it that may have been why i used it.
I recall I chose this as it had higher static pressure which is good when using it with a radiator.
I think I recall I tried an EK Vardar fan as well but the result was too noisy.
Note i sit less than 1mtr from my microserver.
Edited by fury
Gulftown
Non-PWM version of NF-P12 is 1300RPM, 92,3 m³/h,  19,8 dB(A), 1,68 mm H₂O. Does it really have 3-pin connector, not 4?
I would like to test a new Redux PWM version. What seems to be really important to me is low power consumption (that affects all bew fans) as I can use more fans using the same power line.
I wanted to implement possibility to add CPU, RAID cooling  as well. The good thing is Delta AFB1212SH(-R00 RD-lock version actually that is the thing I was telling you about the problem with mihai's solution... it will work but in the state of rotation lock detection just waiting for some time to sound the alarm and having not ehough time for that) consumes 0.8A while your fan needs only 0.09A to operate. As for Redux generation 0.05A will be enough so you can power 10 fans using the same connector. 😀
As far as I understand you have spent a huge amount of money to buy a separate connector so in case of failure you can still use the old one. I didn't accept this solution as you get a no good implementation of RD for high cost.
But to make it work MCU-controlled you have to make a LOT of research and measurements (I had to use "some" specification whitepapers and I don't still know how to make my board work with your 3-pin type of fan due to PWM-TACH signal distortion). I think I have to finally make it done and place everything I found on the topic to this forum.
    • oldwhs12
      By oldwhs12
    • AVsonyfan
      By AVsonyfan
      Tips:
    • gru
      By gru
      Hi! I am planning to buy a Microserver Gen10 Plus E-2224 for a small business, and want to add as much disk space as possible. I already have the older Gen10 with 4x4TB HDDs in RAID10 (effective capacity 8TB) and a 2TB SSD in the 5th slot (which is missing on the new G10 plus). The max stated capacity on the HPE site seems to be limited with their own enterprise HDDs, so I'd like to see if I can go for bigger disks. The server would be running a sort of an application which collects lots of data from devices, and the data tends to grow over time (1-2TB per year), and I'd prefer not to worry about the capacity for the next several years.
      My primary concern is the max capacity (max single drive capacity + max total RAID capacity with the Smart Array S100i) I can reliably install. If possible, some actual setup which has been shown to work with 32GB RAM and its limited 180W power supply? I was also planning on upgrading it to 32GB. If I am buying a 16GB RAM server, does this means it has both slots occupied with 8GB modules and I need a 2x32GB kit? For the os SSD, I won't have the PCIe slot available because we need to insert a certain GPS PCIe card that the server uses for time synchronization. So, if I want an SSD, this means I should use something like 1xSSD + 3xHDD in RAID5, instead of RAID10?
      I've been planning to install 16TB Seagate Exos X16 drives, with rated max operating power at 10W (6.3W for random reads/writes). Does this seam feasible?
      Thanks a lot for your tips!
    • E3000
      By E3000
