ILO Integrated Remote Console screen resolution
mammifero
Good Morning to All from Italy
i have installed a "new" graphics card on my Gen8 but after that i'm not able to use the ILo remote console.
i can launch the remote connection but after the first screen i obtain only a black screen, i think that i have to use a monitor
bye
Hi you need to change the graphics setting in the bios can’t remember what it says but it’s the bottom option then you can use ilo and graphics card even after passthrough on ESXi
My 5 cents: after You set "external graphics primary, integrated - secondary", You can`t see anything in iLo after POST. But after OS is loaded and You extend display to second monitor (clone or duplicate - doesn`t matter), You can move cursor in iLo and see it on monitor, but still nothing in iLo... So You can`t fully use iLo.
