ETBrown Posted January 11, 2018 Share Posted January 11, 2018 I am finally replaced my custom built desktop PC after about 5 years. Now that I have a retired computer with a decent pair of video cards I want to dip my toe into cryptocurrency mining. Although I realize the old equipment won't produce as much per watt as newer graphics cards, I already have 2 HD 7870's that will just collect dust if I don't do something with the system. There are also a few older components lying around so I've been contemplating repurposing my old computer and components to create computers for the following roles: A dedicated storage server that would also host my Plex media server and backup content locally. (Yes a NAS box could do this, but I already have PC parts and don't want to spend $1k+ on a NAS box that can accomodate all of my 4TB and 6TB drives). A cryptocurrency mining rig A router/firewall replacement I'm new to mining and know that the mining rig needs graphics cards, but how significant of a difference does the CPU make in a mining rig? I can either use an Intel Core i7-3770K or an Intel Core i3-3250. The dilemma is that the i7 should be able to transcode roughly twice the number of simultaneous streams (4) that the i3 can transcode (2+) based on the PassMark scores. I don't want to mine on the same machine as my Plex server since my previous mining attempt created OS stability problems. Does memory make a large difference in cryptocurrency mining? I can either use 32 GB of ram or 16GB of ram. Lastly, would it be better to combine the storage/Plex server and router/firewall roles into a single computer and run each as a VM? What do others recommend for this? I've heard about Pfsense and watched a few setup videos, but that appears to be designed to run on a dedicated system. Thank you in advance to those that have constructive feedback for me. Link to comment Share on other sites More sharing options...
thanlindley Posted January 12, 2018 Share Posted January 12, 2018 My opinion would be to use the core i7 and lots of storage and RAM that you have to make a Plex server/storage/transcoder in one box. That much RAM and CPU would be a waste on a mining rig. If you wanted to check the power supply and have decent graphics cards (Nvidia 1060 and up) the use as little RAM and slower ( low power) CPU to make a mining rig. My preference is to keep pfsense stand alone although I know others have virtualized it. Link to comment Share on other sites More sharing options...
Trig0r Posted January 12, 2018 Share Posted January 12, 2018 From a crypto pov, you can tweak the config of the miner so that it uses some or all of the cores, the 3770K is a smidge faster than my straight 3770 should see ~350H/s on Monero algorithm, obviously, you'll have to see how transcoding goes and tweak accordingly, it'd probably net you ~$2 a day, not sure what the 7870's will do, I suspect >400H/s. Link to comment Share on other sites More sharing options...
