Wifi card for n40l
DNA1
I just bought a Netgear r7000 so figured I would upgrade my n40l connection, it is still using a Powerline because Ethernet is not possible.
I have never bought a wifi card so I do not really know what to look for.
My n40l already has a graphics card in one of the slots so it needs to be a PCIe x1 one?
I want to spend around £10-20.
Anyone got any good recommendations?
EDIT: Router is under 3m away in the same room so crazy antenna are not necessary
Edited by DNA1
You need it to be PCIe x1 and low profile. The more you spend the faster connection you get. In your price range I would look at:
Asus PCE-AC51 $30
https://www.asus.com/us/Networking/PCE-AC51/
Edimax Network EW-7612PIN V2 N300 $23
http://www.edimax.com/edimax/merchandise/merchandise_detail/data/edimax/au/wireless_adapters_n300/ew-7612pin_v2/
Asus PCE-AC51 $30
Thanks, the AC51 you mentioned is about £35 here so that is almost double my budget.
The Edmiax is nice and cheap though thanks!
EDIT: Just noticed the Edmiax is not dual band
How about the TP-LINK TL-WDN4800 N900?
https://www.amazon.co.uk/TP-LINK-TL-WDN4800-Wireless-Express-Antennas/dp/B007GMPZ0A
Edited by DNA1
The TP-Link is more expensive than the Asus and I can't tell if it comes with a low profile bracket, it looks too tall. You may want to look at installing a USB 3.0 card and using a USB 3.0 WiFi adapter. I know the cheaper card is 2.4Ghz only, it is only 802.11n so it won't go any faster on 5Ghz. You may want to look for a used card on eBay if you want a faster card for less money. If you are only 3M from the router, are you sure you can't use an Ethernet cable?
Unfortuantly in the UK, the Asus is £7 more expensive than the TP link. I will look into using a usb adapter. To connect via Ethernet it would have to go around a whole room, then over 2 doors, possible but would be quite the eyesore.
EDIT: Good idea getting it used, i do not mind getting used stuff.
Edited by DNA1
