Memory problems
gustavocurzio
Hi,
Any one already had a problem with memory slot? i have a kingston KTH-PL316E/8G on slot 2 installed, but if i change to slot 1, it doesn´t work, when i try to turn on, it reset after 20% of the first load screen, is this slot problem?
Thank you
Regards
Hi,
just one, today i´m using it on slot 2, but when i change the place and put one the first, it doesn´t work
