Google Home With Smart Switches
ImTheTypeOfGuy
Anyone using Google home with light switches? If yes what switches are you using? I have found several that work with single poles but I need single and multiple pole switches. I would like to find one brand that works with Google home and had both pole arrangements. Oh, and I prefer ones that do not require a hub.
I know hook works well with outlets but they don't make switches.
  • 7 months later...
Alternative, the TP-Link Switch is compatible with Home/Assistant, as are their Plugs and LED Bulbs. Note that there is no IFTTT support as of yet.
