jjbrunton Posted December 18, 2017 Share Posted December 18, 2017 I've purchased a P410 that I've installed into the PCI slot but I'm having issues trying to get my SSD to be recognized by it, I've tried all sorts of combinations: Disable b120i - Nope Change to SATA legacy mode - nope Change to AHCI mode - nope In all of these configurations, the card is unable to see the SSD. I'm assuming it is because I need some way to plug the SSD into one of the SAS ports? Link to comment Share on other sites More sharing options...
schoondoggy Posted December 18, 2017 Share Posted December 18, 2017 What type of cable are you using to connect the SSD to the P410? Link to comment Share on other sites More sharing options...
schoondoggy Posted December 18, 2017 Share Posted December 18, 2017 I re-read your post. Yes you need a SFF-8087 to SATA cable to connect the SSD to the P410. Also be sure to up date the firmware on the P410. https://www.newegg.com/Product/Product.aspx?Item=9SIAERN68H8118&cm_re=SFF-8087_to_SATA-_-9SIAERN68H8118-_-Product Link to comment Share on other sites More sharing options...
jjbrunton Posted December 18, 2017 Author Share Posted December 18, 2017 39 minutes ago, schoondoggy said: I re-read your post. Yes you need a SFF-8087 to SATA cable to connect the SSD to the P410. Also be sure to up date the firmware on the P410. https://www.newegg.com/Product/Product.aspx?Item=9SIAERN68H8118&cm_re=SFF-8087_to_SATA-_-9SIAERN68H8118-_-Product Perfect, that cable looks like what I need. Thanks Link to comment Share on other sites More sharing options...
