HELP: 1 Gb of RAM for Hardware ?
juan3211
HI, I have purchased a GEN 10 microserver (version CPU AMD Opteron X3216 / 1.6 GHz with 8 Gb RAM).
I have installed Server 2016 Standard (two hard disk: 2Tb and 4Tb RED) but I have a problem with memory.
In windows server it says: 8 Gb RAM (6,96 GB available).
I have:
  • install video driver from HP web page
  • uninstall it and leave the basic default driver
  • check all BIOS option to search for a option for the shared video card memory.  (I haven't found anything)
So no luck.
Does any body knows how to increase the available RAM ?
Regards,
5 minutes ago, schoondoggy said:
The AMD CPU has a GPU built in. I assume the missing memory is dedicated to that.
Me too. But I expect to have some option in BIOS not to "spend" 1 Gb in video memory for a server, don't I ?
Not really. The server has capability for multiple 4k displays. Even one 4k display using normal desktop software can exceed 1GB RAM so it would make sense that they'd set that as a minimum level. To be honest even if you could reduce it I doubt it would accept below 512mb.
