Gen 8 CPU Auto Fan Temperature Switch
Steventon's IT World
Hi all,
You might have seen my other post about a way to install two CPU fans to the heatsink of the Micro Server Gen 8 on the forum. If not then check it out here. I posted full instructions on my blog here.
I am trying to find a way to stop the noise of the fans when the server isn't producing much processor heat. I think a temperature switch is the best way to go. Something like in the image attached. It allows me to change the temp value but it looks like it might only turn off the switch when it gets hot. I want this the other way around. Does anyone know if this is the case or whether this item would actually work?
Many Thanks
