itGeeks Posted November 14, 2017 Share Posted November 14, 2017 (edited) I am looking for a 2 or 3U short depth rack-mount case that supports 12 Hot-Swap drives that supports both 2.5 and 3.5 drives. The case needs to support MicroATX motherboard and be no more then 19-21 inches deep. The motherboard I have is a Supermicro X10SLL-F and the server rack I have is a wall mount by NavePoint found here This will be used for a XPEnology build. Thank you in advance. Edited November 14, 2017 by itGeeks Link to comment Share on other sites More sharing options...
schoondoggy Posted November 14, 2017 Share Posted November 14, 2017 This is 22.83" deep and the bays are trayless, so you would need to use adapters for your 2.5" drives: http://www.istarusa.com/istarusa/products.php?model=DAGE312UTL-NAS#.Wgsd5iWpouU 1 Link to comment Share on other sites More sharing options...
itGeeks Posted November 14, 2017 Author Share Posted November 14, 2017 schoon thank you so much for taking the time. That case looks good but it's to fat on the depth, My rack has a max usable depth of 600mm/22" deep. Any other ideas? I found a Norco case that is 15.25 inch deep but it only holds 4 drives found here. I am truly stumped on this one, Most cases I found are 25+ inches deep. Link to comment Share on other sites More sharing options...
itGeeks Posted November 14, 2017 Author Share Posted November 14, 2017 Update: Schoon the outside dimension of the depth is 600mm/23.5 but the rail depth is 20.5 so that case wont work. here are the specs for the rack. Hope you can find something that will work. Thank you Link to comment Share on other sites More sharing options...
schoondoggy Posted November 15, 2017 Share Posted November 15, 2017 The rail depth is the measurement from the front rail mount bar to the back rail mount bar. So, rail kits for this enclosure will need to be able slide down to 20". Were you planning on putting this on slide railes or fixed rails? That said it looks like there is only 22" of useable internal space. How many 'U' do you have available? If you have 6U you could do something like this: server board in this http://www.istarusa.com/en/istarusa/products.php?model=D-213-MATX-DT With two of these running IT firmware (HBA) https://www.ebay.com/itm/LSI-SAS9205-8e-Host-Bus-Adapter-8-Port-6Gb-s-PCI-E-HBA-SATA-SAS-No-Bracket/253249726832?hash=item3af6dc2970:g:0zIAAOSwIFtaALod cabled down to this http://www.istarusa.com/istarusa/products.php?model=E-490-JB#.WguSbmiPIuU with three of these http://icydock.com/goods.php?id=242 15 drives in a 4U JBOD and XPEnology running on a 2U server. Link to comment Share on other sites More sharing options...
schoondoggy Posted November 16, 2017 Share Posted November 16, 2017 How about fourteen drives, ten 3.5" and four 2.5" drives in a 4U case that is 20.8" deep? Amazon is showing 22" internal depth on the rack you have, so this case should work. This case: https://www.newegg.com/Product/Product.aspx?Item=N82E16811165552 Two of these: http://icydock.com/goods.php?id=242 Two of these: http://www.icydock.com/goods.php?id=234 One set of 20" slide rails: https://www.newegg.com/Product/Product.aspx?Item=N82E16816215017&cm_re=slide_rail-_-16-215-017-_-Product Link to comment Share on other sites More sharing options...
scruffters Posted November 16, 2017 Share Posted November 16, 2017 Ablecom CS-R26... 533mm deep. There is also a CS-R25, which is the 8x drive version. Personally I use the Supermicro 826E16/836E16 a lot - not at home, in production. I like these because they have port expanders built in (hence the E16 code). There are also 12G variants. All work well with LSI MegaRAID controllers. These are 650mm deep though. I think Ablecom are Supermicro's parent company... http://www.ablecom.de/Products/chassis/CS-R26/ 1 Link to comment Share on other sites More sharing options...
schoondoggy Posted November 16, 2017 Share Posted November 16, 2017 3 hours ago, scruffters said: Ablecom CS-R26... 533mm deep. There is also a CS-R25, which is the 8x drive version. Personally I use the Supermicro 826E16/836E16 a lot - not at home, in production. I like these because they have port expanders built in (hence the E16 code). There are also 12G variants. All work well with LSI MegaRAID controllers. These are 650mm deep though. I think Ablecom are Supermicro's parent company... http://www.ablecom.de/Products/chassis/CS-R26/ Nice find! Ablecom are nice cases. I did find a 3U 16 drive JBOD that is only 19" deep if you are still concidering a two chassis solution: http://www.istarusa.com/istarusa/products.php?model=EA-3M16-JB#.Wg3PZWRaMuU Link to comment Share on other sites More sharing options...
scruffters Posted November 16, 2017 Share Posted November 16, 2017 I wish they bought these into the UK more readily, Schoon. I've had a good for requests for short/compact racks over the last couple of years. It seems to me the momentum behind QNAP et al is really starting to affect the NAS case market. I've even let me mind go to that place where I started thinking about designing my own. There is a U-NAS case out there, but it's so cheap looking that I couldn't consider it for what I'm doing. Link to comment Share on other sites More sharing options...
itGeeks Posted November 17, 2017 Author Share Posted November 17, 2017 wow lots to digest here. Schoon your setup recommendation is very creative and one that I had never thought of. I really wanted to keep everything in one case but its becoming clear this may not be possible with the rack I have. After looking at ur suggestion I found a Norco storage case that I like though a bit more expensive then your recommendation, It includes everything needed so I don't have to build my own with Icy Dock components. This is the case, What do you think? @scruffters, I agree with schoon nice find. I got all excited about this Ablecom CR-R26 case till I was reading the specs, It looks like it only supports ATX motherboards and I have a MicroATX. Can you confirm it will support my motherboard? Also I don't see it offerd in the US, Can you confirm it's sold in the US?? I would purchase this case in a heart beat if you can confirm the above. I really want to build everything into a single case to eliminate a failure point on my build. @scruffters, Whats wrong with the U-NAS cases? What are you doing that these cases would not handle? I would use the U-NAS cases in a heart beat if I was not trying to build a rack mount solution. Thanks again to everyone that has taking the time to try and help Link to comment Share on other sites More sharing options...
