Raid 1 and failure of hardware.
rodzynx
Hello,
A few months back I had a very simple setup of my N54L where all drives were simply connected and in case of any problems I could connect them to any other computer and read the data.
Since I moved to Gen8 I decided to invest and take advantage of Raid 1.  The Idea is brilliant as this will protect me from a failure of one drive but will it protect me from Hardware failure?
So my questions are; If a build in controller dies:
  1. Is it possible to keep, save, retrieve written data (assuming that both drives are working)?
  2. Would I be able to just connect the drives to any Raid controller or does it have to be the identical controller (another gen8)?
  3. How to protect myself from that kind of scenario?
  4. If let's say I have OS drive in ODD bay can I reinstall windows, not touching any of arrays) and still keep the data or reinstallation of Windows will destroy the configuration. I think it should be ok as the array is not software but just wanted to check before I start messing around with reinstallation.
Thank you
Edited by rodzynx
Oh my, you're bringing back some memories for me. Let me quote, as near as I can, what my father would tell you:
"RAID is not a form of backup; it's a form of resiliency". I'm not sure that's exactly how he put it, but he told me over and over that the 3-2-1 backup system, or something very similar, is the only way to keep data safe. He told me that RAID is a way of helping keep a system up and running; in other words, a way of reducing or stopping system crashes due to disk failure.
I don't know about different RAID cards, but people seem to make a big deal out of the fact that DrivePool can pick up and rebuild drive pools, even if the drives are moved to another computer. That makes me wonder if that's because RAID cards don't do that. Otherwise, why point it out so much?
Hi Ikon-TNG,
Don't take me wrong, I know that rule and I have a backup of a backup, but as I was always using raid at work I have never thought of what if scenario. Now when I implemented Raid at home I was wondering.
When you say "DrivePool" do you mean Stablebit Drivepool software?
thx
Edited by rodzynx
@rodzynx My father would be happy to hear you have multiple backups. It's something he constantly stressed to family & friends. He hated the idea of people losing important info.
Sorry for not being clearer: yes, I meant Stablebit DrivePool.
RAID sets are generally able to be migrated to other controllers from the same vendor. The RAID1 set in your MS Gen8 could be pulled and moved to a different HP server with a B120i or newer Dynamic RAID controller. The RAID set could also be moved to a HP Smart Array controller like a P222. You can not move RAID sets from HP to LSI or Adaptec based controllers. Your last point is very imporant, it is best to keep data and OS separate from each other. If you have an OS drive failure, you could replace the drive and install the OS without affecting your data.
@schoondoggy  would you be able to direct me towards some instructions on how to do it?
Thx
Very interesting. My mind immediately went to this analogy: some parts of, for example, GM vehicles can be moved from one model to another, but not from a GM vehicle to a Ford or Chrysler. In your opinion, is that a fair analogy?
Thx
Pages 24-25 cover moving RAID sets:
https://support.hpe.com/hpsc/doc/public/display?docId=c03326739
That would be a fair analogy. You just need to understand the rules that apply.
The devil is always in the details......
