Are we stuck without a RHEL/CentOS 7.4 HPVSA driver?
Kingeth3
After restarting my server recently, I realised that my CentOS had updated to 7.4, and with it, the kernel updated from 3.10.0-327 to 3.10.0-693. The change was particularly noticeable, since my system would no longer boot. The issue is with the HPVSA driver, and is documented by others at:
https://bugs.centos.org/view.php?id=13943&nbn=4
https://www.reddit.com/r/linuxquestions/comments/701qnt/can_i_use_an_older_kernel_on_an_otherwise/
https://community.hpe.com/t5/ProLiant-Servers-ML-DL-SL/Drivers-for-B120i-for-RHEL-7-4/m-p/6972868#M158669
The final link shows a discussion on the HPE forums, where "Jimmy Vance" says that HPE is working on a new driver; however I haven't found any other information online about this. The second link shows a Reddit discussion, where "5ilver" suggests to "build a new initrd that includes them in the preboot environment. And or run depmod" – but I don't know how to do this.
Does anyone have any additional information on this situation, or is everyone waiting and crossing their fingers? I understand that SATA AHCI mode is an acceptable fallback in the end.
AFAIK Jimmy Vance works for HP so his information should be accurate. I'm not sure if initrd trick would work. I tried running 7.4 installer with 7.3 driver, it loads but kernel panics shortly afterwards, so it seems that the driver just isn't compatible with new kernel.
Edited by vbezhenar
Not sure with CentOS and i have not dabbled with REHL since i started with ESX (no i) which was a cut-down version of RHEL. for RHEL could you not use the driver from ESXi now?
if I'm way off the mark, just put me back in my box.
