CablDeViL Posted December 15, 2010 Share Posted December 15, 2010 Just noticed on my new HTPC that when I shut off my system the HTPC turns fully off . Then when I use the remote to turn it on it will not power up (no power to the usb IR). I did the usual and told Win7 to power off to hibernate but that did not help. What should I try next and what are the recommended Bios and Win7 power settings on a HTPC. Thank you in advance for saving me 2 hours of playing around tonight. Bill Link to comment Share on other sites More sharing options...
Guest no-control Posted December 15, 2010 Share Posted December 15, 2010 Put it to sleep not off. Link to comment Share on other sites More sharing options...
CablDeViL Posted December 15, 2010 Author Share Posted December 15, 2010 Ok I will tell w7 to go to sleep on "power off" command via da remote. TY Mikey Link to comment Share on other sites More sharing options...
Jazman Posted December 15, 2010 Share Posted December 15, 2010 Just noticed on my new HTPC that when I shut off my system the HTPC turns fully off . Then when I use the remote to turn it on it will not power up (no power to the usb IR). I did the usual and told Win7 to power off to hibernate but that did not help. What should I try next and what are the recommended Bios and Win7 power settings on a HTPC. Thank you in advance for saving me 2 hours of playing around tonight. Bill Setting it to sleep is one option. The other is to to just leave the power on all the time. Depending on your HTPC, that may or may not be an issue. For me, one draws alot more power than the other. Keith Link to comment Share on other sites More sharing options...
