Will PC4-17000 work with X3216?
Kelv1n
Hi Folks
Wondering if somebody could advise, I'm looking to purchase 32GB RAM for my HP Microserver Gen10, and have been offered  2x16GB PC4-17000 DDR 2133P... Would this work in one of these boxes?
Speed wise, I'm not too fussed about.
Hi Schoon
It apparently "support ECC error correction and detection"..
https://www.skhynix.com/products.view.do?vseq=1944&cseq=75
1 last question, I read UDIMM, just means unregistered DIMM.. So I'm assuming registered RAM such as this will not work?
https://www.uk.insight.com/en-gb/productinfo/computer-memory/0005923118-00000001
Thanks again
Edited by Kelv1n
Update
    • Appfillip
      By Appfillip
      Hi, Everyone But facing problem regarding My Desktop of getting randomly Blue screen and shutdown. Sometime It won't even start because as I start my CPU and it had blue screen and shut down. I don't know what should I Do but changed my RAM and I thinking to change my Motherboard.
    • E3000
      By E3000
      Hey guys,
      Bit of a random question here, and I know it depends on many factors such as what they are doing etc, but how many VMs have you guys comfortably ran on Gen8 with an E3-1265v2 and 16GB RAM? When did you start to see a performance hit compared to what the Gen8 is generally capable of?
    • dxzdxz1
      By dxzdxz1
      This is my first post here but I've been lurking in this forum for quite sometime now, and from what I understand, the only reason that we couldn't achieve 32gb ram on the Microserver Gen8 was because there was no 16gb unbuffered ecc ram available before.
      I was searching for a memory module meeting this criteria and I found this one. My question is, letting aside this ridiculous price, is there any compatibility issue that could make this ram won't work on the Microserver Gen8?
      Most of the threads here about memory compatibility are quite old and I didn't want to revive an old thread just to ask this, so I'm creating this one.
      Thanks in advance.
    • Orion
      By Orion
      I am building a Ryzen machine. Using the new Ryzen 7. What is the best ram to use. Obviously ddr4. And recommendations on brand and size
    • 50pence
      By 50pence
      Apologies if posted before but a weird one I’m hoping someone can help me figure out (probably bought the wrong ram! 😒)
      Stock Gen8 with Celeron G1610T CPU & 4GB RAM (
      Upgraded to
      e3-1256L v2 with 65w HP Heatsink
      Offtek 16GB (2 x8GB) DDR3 1600MHz 2R x8 ECC
      Offtek ram was bought sometime ago and registered fine in bios with the celeron.
      Since upgrade of cpu & heatsink - the RAM slot closest to heatsink just doesn’t want to work. Tried swapping ram modules around. Single slots used. The slot furthest away from heatsink seems to work fine with all ram modules.
      See pictures of failures and ram used.
      The bios jut seems to loop around at 30% when Any ideas??
