rickU2D Posted September 9, 2017 Share Posted September 9, 2017 Hi Guys, Was hoping someone with experience with Freenas might be able to help. I set up Freenas on my gen8 and everything was working great. Freenas was installed with a network cable plugged in to the Ilo port. All was fine until I needed to re-arrange my office. Shutdown the gen8, unplugged the cable. moved everything, plugged it back in. Now, network interfaces will not connect. Can't ping, etc,. I tried to re-configure the interface from the shell (through Ilo). Tried static, dhcp, tried some tip I read re- disableing msi and msix. No dice. I have an N54L running as a DC. I also tried deleting and re-adding DNS records, so far, to no avail. Anyone deal with this situation before? If this is not an appropriate question for this forum, please excuse me. I was trying to avoid signing up to yet another forum (freenas). Any help greatly appreciated! regards Link to comment Share on other sites More sharing options...
netware5 Posted September 11, 2017 Share Posted September 11, 2017 Hi, I am running Nas4Free on my HP MS Gen8, so it is very close to FreeNAS. My feeling is that software/OS is not the cause for your problem. Did you checked the LAN cable, wall outlet, router/switch ports, etc.? Link to comment Share on other sites More sharing options...
raulico Posted September 12, 2017 Share Posted September 12, 2017 check in the ilo config page the section of "network" then go on "ilo network dedicated port" and "shared network port" section and do a double check. ciao Link to comment Share on other sites More sharing options...
