SSD help with ESXi
Blipstar
Hi all,
I've been a lurker on this site and listener of the podcast for some time and would like to thank all the members/staff for their great tutorials and posts over the time as i've got this far without asking a question until now :).  Now for some back story about my question.
Successfully 2 years ago built my Gen 8 microserver running ESXi  6.0 on the micro SSD card,  2 x 3tb drives running in a raid 1, 16gb RAM and today I upgraded my stock cpu to the Xeon e3-1265l v2
I use the Gen 8 mainly for just Lab testing things, but mainly the 1 VM thats always on is where I run my Plex media server. The media it's self is actually sits on a Buffalo Terastation 13tb NAS.
I' decided to upgrade the CPU today because the server has become a family favourite and usually streams more then 1 movie at a time and it struggles to transcode.  After upgrading the CPU  and installing a new windows 10 OS i realised the OS is always really slow to load because they run from the 2x 3tb raid one NAS drives. So my question is : - is it possible in my setup to add a SSD through the ODD drive with the floppy disk sata adaptor or will esxi not recognise it ?
Thanks all
haha yes,  after all this I worked out that I just needed to provision the drive in the Hp smart array to a logical drive... doh!
    • Haxsource
      By Haxsource
      Good afternoon folks!
      I have a question I was wondering if someone would know about. I have a Microserver Gen 8 with Vmware ESXI 7 currently installed on the MicroSD with AHCI enabled instead of RAID mode (dont find anything usefull in raid mode in my current setup other than booting from ODD, which I can just use as another Datastore instead).
      With that context being said, Im trying to enable the Agentless Management Service from the ILO with the drivers on the Vmware ESXI 7, but unfortunetly after installing and trying to start the service with:
      /etc/init.d/hp-ams.sh start
      I get the following error:
      /opt/hpe/ams/amshelper: error while loading shared libraries: libnicmgmt.so.0: cannot open shared object file: No such file or directory
      Makes sense following the Vmware ESXI HPE support matrix, since its only supported until Vmware ESXI 6.5U2 Pre-gen. But I´ve been reading lots of people having working setups doing the following:
      Install Vmware ESXI HP Custom Image 6.5U2 -> Offline Update to Vmware ESXI 6.7.
      I was wondering if installing HP Custom Image 6.5U2 with the drivers Agentless Management Service working and doing a full upgrade to ESXI 7.0 would do the trick, since its an upgrade not a clean install...so libraries should stay supporting older drivers installed.
      Does this make any sense?? Has anyone gone trough this alredy?
      Thanks!
    • netware5
      By netware5
      ***CRITICAL*** iLO 4 update available here. HPE requires users update to this version immediately. Potential vulnerabilities in network stack.
      VULNERABILITY SUMMARY
      A potential security vulnerability has been identified in Integrated Lights-Out 5 (iLO 5), Integrated Lights-Out 4 (iLO 4), and Integrated Lights-Out 3 (iLO 3) firmware. The vulnerability could be remotely exploited to cause memory corruption.
      HPE has released updated firmware to mitigate these vulnerabilities.
      References: CVE-2020-27337
    • AVsonyfan
      By AVsonyfan
      Tips:
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
