Long time fan, first time poster
antaeus
Hello,
Since I found a Gen8 on the cheap (new), I have looked a lot at this site.
It is currently specced with:
Celeron G1610T
1x 4GB (Original)
1x 8GB hmt41gu7mfr8a-h9 (Lenovo ECC, Unbuffered)
1x WD Green 120 SSD
2x WD Red 2TB (Running dynamic disks)
All running Windows Server 2012 R2
It is currently running an Unturned gameserver, and in due time, I would like it to run something called Seafile. Since the G1610T has a TDP of 35W, I thought of buying a "new" CPU for the box. After some researching I found that the E3-1220Lv2 to be the best match. It is quite expensive... seeing as it is well sought after.
In a lapse of judgement, I ordered an I5-2390T on eBay. It is due to arrive anytime now, and now I am thinking if I did the right thing buying a cheaper CPU. I have seen proof that the CPU will work with my BIOS version (J06).
My questions are these:
1. Should I count my loses, and go for the E3-1220Lv2?
2. If it is a no to question 1, would I have to buy new RAM?
Thank you for your time.
  • Like 2
Go for the E3-1265l v2 insted, you can turnoff the TurboBoost in BIOS so you can get the speed down and also the power consumption and the heat.
It goes for around 120 USD on eBay.com
  • Thanks 1
The only concern with i3 and i5 CPU in the MS Gen8 is ECC support. They work with ECC memory in the server, but do they actually handle memory errors with ECC? There is no easy way to test this. If you were running ZFS or another environment that requires ECC, I would tell you to go with the XEON. I think most users that have moved to an i5 are quite happy with it. I would try the i5. If it does not meet your expectations I would take the advice given by @calby and look for a E3-1265l v2.
  • Thanks 1
I thank you for your feedback. It is much appreciated.
I will try and run with the i5-2390T and see how it runs.
Thank you!
P.S. are there any experiences with fitting active CPU cooling?
There are several threads on active cooling for the MS Gen8. I generally have just added a blower 40mm x 20mm on the side of the original heatsink to force air through.
  • Thanks 1
I think I will just monitor the temperature when the i5 gets installed. Now I know it's an option.
Again, many thanks for helping a home server newbie :)
    • Himaro
      By Himaro
      So I'm trying to replace my ageing HP Proliant Microserver N54L. It's used as a general dogs body server, running Blue Iris, Plex and as my NAS server.
      I'm on a pretty tight budget but the poor server is always at 90% + CPU because of the CCTV and I'm looking at adding a second camera soon.
      Is there such a thing as a reasonably priced ECC home server build?
      My MVP is 8GB ECC memory, with 4 threads on the CPU.
      I'd prefer a small form factor but that's like gold dust unless you throw a lot of $$££€€ at it. I've got to get this past my partner you see 😅
      Any ideas? I'm not loyal to any particular brand, so long as it works.
    • 50pence
      By 50pence
      Apologies if posted before but a weird one I’m hoping someone can help me figure out (probably bought the wrong ram! 😒)
      Stock Gen8 with Celeron G1610T CPU & 4GB RAM (
      Upgraded to
      e3-1256L v2 with 65w HP Heatsink
      Offtek 16GB (2 x8GB) DDR3 1600MHz 2R x8 ECC
      Offtek ram was bought sometime ago and registered fine in bios with the celeron.
      Since upgrade of cpu & heatsink - the RAM slot closest to heatsink just doesn’t want to work. Tried swapping ram modules around. Single slots used. The slot furthest away from heatsink seems to work fine with all ram modules.
      See pictures of failures and ram used.
      The bios jut seems to loop around at 30% when Any ideas??
    • Joe_Miner
      By Joe_Miner
      Anyone found good deals for RAM for the ML30 Gen9?
      This is what I'm seeing for requirements in the QuickSpecs
      HPE ProLiant ML30 Gen9 Server QuickSpecs http://h20195.www2.hp.com/v2/GetDocument.aspx?docname=c04834998&doctype=quickspecs&doclang=EN_US&searchquery=&cc=us&lc=en
    • texasPI
      By texasPI
      I'm looking to build a new daily driver with an i5-2500k. It seems like I want a Z68 mobo and I'm leaning toward Gigabyte. What do you guys think?
