Notbugged Posted August 4, 2017 Share Posted August 4, 2017 Which one is better and faster? Anyone tried this? Or I better off with a generic microSD card? HPE 32GB microSD Mainstream Flash Media Kit https://www.hpe.com/us/en/product-catalog/servers/flash-media-devices/pip.hpe-32gb-microsd-mainstream-flash-media-kit.5360695.html THANKS Link to comment Share on other sites More sharing options...
richu75 Posted August 4, 2017 Share Posted August 4, 2017 Both should work, but I had corruptions on my sd card after some time. In the end I plugged in an old usb stick and never looked back.I assume you are going to install esx? Link to comment Share on other sites More sharing options...
marked Posted August 4, 2017 Share Posted August 4, 2017 Depends on what you are going to use it for. I just use a 16GB Sandisk Fit USB3.0 flash for running ESXi 6.0u2. Runs about £8. Link to comment Share on other sites More sharing options...
