HP Microserver Gen 8 "LUN Reset from host for unit U01"
ioeprat
Hi there!
My Gen8 runs Windows server 2008 r2,with 4x WD Red drives in the internal drive bays connected to the on board B120i(Raid 10). I have noticed some log with HP ProLiant Smart Array SAS/SATA Event Notification Service in C:\Program Files\HP\Cissesrv\slot0.txt, and I don't understand this(LUN Reset from host for...), is something wrong?
[07/13 03:18:54] *** Memory info ***
[07/13 03:18:54] Pool        Size       Used      Avail Used%
[07/13 03:18:54] ----- ---------- ---------- ---------- -----
[07/13 03:18:54] LREQ        1036         12       1024    1%
[07/13 03:18:54] PREQ        1127        106       1021    9%
[07/13 03:18:54] Shared Memory Avail 6451352 bytes
[07/13 03:18:54] XRRAM   58720256    6083584   52636672   10% largest=  52374528 (bytes)
[07/13 03:18:54] XRRAM     114688      11882     102806   10% largest=    102294 (sectors)
[07/13 03:18:54] deferred_free_lpram_head = 0x0000000000000000
[07/13 03:19:36] Host: Time is 7/13/2017 3:19:36
[07/13 03:19:45] iLO command polling interval=0.090 seconds, hostaddr=0xFFFFF88002BD6020.
[07/13 03:28:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/13 04:26:46] LUN Reset from host for unit U00 (cmds=2, logical_io_count=1)
[07/13 05:38:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/13 05:44:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/13 05:52:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/13 06:24:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/13 06:32:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/13 06:32:51] LUN Reset from host for unit U00 (cmds=1, logical_io_count=1)
[07/13 07:00:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/13 07:36:46] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/13 07:40:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/13 08:08:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/13 08:48:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/13 09:38:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/13 10:08:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/13 12:02:46] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/13 12:12:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/13 14:40:51] LUN Reset from host for unit U00 (cmds=1, logical_io_count=1)
[07/13 18:26:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/14 03:19:47] Host: Time is 7/14/2017 3:19:47
[07/14 03:32:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/14 05:42:51] LUN Reset from host for unit U00 (cmds=1, logical_io_count=1)
[07/14 11:34:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/14 18:10:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/14 21:46:51] LUN Reset from host for unit U00 (cmds=1, logical_io_count=1)
[07/14 22:28:51] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/15 03:19:48] Host: Time is 7/15/2017 3:19:48
[07/15 09:12:50] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
[07/15 09:42:50] LUN Reset from host for unit U00 (cmds=1, logical_io_count=1)
[07/15 11:48:50] LUN Reset from host for unit U00 (cmds=1, logical_io_count=1)
[07/15 13:02:50] LUN Reset from host for unit U00 (cmds=1, logical_io_count=1)
[07/15 13:06:50] LUN Reset from host for unit U01 (cmds=1, logical_io_count=1)
Many thanks to all for your precious help!
    • Haxsource
      By Haxsource
      Good afternoon folks!
      I have a question I was wondering if someone would know about. I have a Microserver Gen 8 with Vmware ESXI 7 currently installed on the MicroSD with AHCI enabled instead of RAID mode (dont find anything usefull in raid mode in my current setup other than booting from ODD, which I can just use as another Datastore instead).
      With that context being said, Im trying to enable the Agentless Management Service from the ILO with the drivers on the Vmware ESXI 7, but unfortunetly after installing and trying to start the service with:
      /etc/init.d/hp-ams.sh start
      I get the following error:
      /opt/hpe/ams/amshelper: error while loading shared libraries: libnicmgmt.so.0: cannot open shared object file: No such file or directory
      Makes sense following the Vmware ESXI HPE support matrix, since its only supported until Vmware ESXI 6.5U2 Pre-gen. But I´ve been reading lots of people having working setups doing the following:
      Install Vmware ESXI HP Custom Image 6.5U2 -> Offline Update to Vmware ESXI 6.7.
      I was wondering if installing HP Custom Image 6.5U2 with the drivers Agentless Management Service working and doing a full upgrade to ESXI 7.0 would do the trick, since its an upgrade not a clean install...so libraries should stay supporting older drivers installed.
      Does this make any sense?? Has anyone gone trough this alredy?
      Thanks!
    • netware5
      By netware5
      ***CRITICAL*** iLO 4 update available here. HPE requires users update to this version immediately. Potential vulnerabilities in network stack.
      VULNERABILITY SUMMARY
      A potential security vulnerability has been identified in Integrated Lights-Out 5 (iLO 5), Integrated Lights-Out 4 (iLO 4), and Integrated Lights-Out 3 (iLO 3) firmware. The vulnerability could be remotely exploited to cause memory corruption.
      HPE has released updated firmware to mitigate these vulnerabilities.
      References: CVE-2020-27337
    • AVsonyfan
      By AVsonyfan
      Tips:
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
