HP Microserver Gen 10 will start at $399
Dave
  • 1 month later...
For sale in my country, for 226,72 €
Hewlett-packard SERV HPE MicroServer Gen10 X3216 1.6-3.0GHz 1x8GB NHP LFF Server 1-1-1 873830-421
No HDD. no optical drive
Price is £225 on Serverdirect for the entry model + 8GB ram. I believe this is much cheaper than the gen8s when they were first released.
On ‎14‎/‎08‎/‎2017 at 0:14 PM, Joe_Miner said:
I wonder when prices will really get competitive in GB like they did with the 7 Gen's?
Not taking too long ...
... my preferred supplier is ServersPlus which is now showing ..
https://www.serversplus.com/content.asp?pageid=88
£140 for a base specification Gen 8 and £166 for a Gen10, after cashback.
let's hope for a real machine, Microserver Gen10 v2 :)
by the way, good price in serversplus. it is my favorite supplier also
Edited by FreeN@S
    • oldwhs12
      By oldwhs12
    • AVsonyfan
      By AVsonyfan
      Tips:
    • gru
      By gru
      Hi! I am planning to buy a Microserver Gen10 Plus E-2224 for a small business, and want to add as much disk space as possible. I already have the older Gen10 with 4x4TB HDDs in RAID10 (effective capacity 8TB) and a 2TB SSD in the 5th slot (which is missing on the new G10 plus). The max stated capacity on the HPE site seems to be limited with their own enterprise HDDs, so I'd like to see if I can go for bigger disks. The server would be running a sort of an application which collects lots of data from devices, and the data tends to grow over time (1-2TB per year), and I'd prefer not to worry about the capacity for the next several years.
      My primary concern is the max capacity (max single drive capacity + max total RAID capacity with the Smart Array S100i) I can reliably install. If possible, some actual setup which has been shown to work with 32GB RAM and its limited 180W power supply? I was also planning on upgrading it to 32GB. If I am buying a 16GB RAM server, does this means it has both slots occupied with 8GB modules and I need a 2x32GB kit? For the os SSD, I won't have the PCIe slot available because we need to insert a certain GPS PCIe card that the server uses for time synchronization. So, if I want an SSD, this means I should use something like 1xSSD + 3xHDD in RAID5, instead of RAID10?
      I've been planning to install 16TB Seagate Exos X16 drives, with rated max operating power at 10W (6.3W for random reads/writes). Does this seam feasible?
      Thanks a lot for your tips!
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
