HP Microserver Gen 10 will start at $399
Dave
On ‎23‎/‎06‎/‎2017 at 8:45 PM, Dave said:
I really think I want to get one this go round.  Last I had was the N54L. I need a Plex server and think ClearOS might do the trick.  HP should send me one to test!
I've been thinking of streaming 4K ...
... but it took me  a lot of investigation to get bit-perfect audio playback on Windows with all the variants in media types and sources.
Anyone got a good handle on all the issues? Codecs VP9,H265; protection HDCP; signalling displayport whatever version; HDR; refresh rates; ...
Eventually got everything sorted with a LINX 1010E tablet @ £99 refurb from ebay.
Experimenting with a CHUWI Hi13 tablet (love the screen size and quality) @ £260 new for video.
Edited by JackoUK
On 24/6/2017 at 0:39 PM, Trig0r said:
Probably translate to £399....
The Gen8 is £120 after rebate in the UK. If the Gen10 is a 'cost cutting' model (many features taken out) do you think it will eventually reach £99 or lower in the UK?
No, the "after rebate" cost is in no way, IMHO, an indication of what cost the Gen10 will be.
The Gen8 is currently, as I can find it, around the £190 mark for the G1610T, 4Gb RAM, no optical and no HDD's.
I've asked my supplier what Gen10 stuff he has, if any..
:D
Won't be buying them from there at that price lol
Gen10 Entry (X3216, 8Gb, 0Gb) £294
Gen10 Entry (X3216, 8Gb, 1Tb) £330
Gen10 Performance (X3421, 16Gb, 0Gb) £427
On 6/24/2017 at 0:22 PM, alex1002 said:
Do these server have the amd cpus based on the new EPYC? Zen technology or still the old and cpu Tech?
Sent from my LG-H831 using Tapatalk
They are not Zen technology. They are part of the Opteron APU line:
http://www.amd.com/en/opteron
So basically it's a good idea to snap up the Gen8 at those prices while stocks last...?
You could do if you can find them at a decent price and then get the rebate put through before it ends as they tend to run for a certain amount of time...
Once they're all gone the second-hand market might improve a bit and I can sell mine lol
Bought mine from newegg for $381
Price is higher for the early adopters, I'm sure there will be better deals in a year or so but I needed a new server now.
Can you post a link to the model you bought?
    • oldwhs12
      By oldwhs12
    • AVsonyfan
      By AVsonyfan
      Tips:
    • gru
      By gru
      Hi! I am planning to buy a Microserver Gen10 Plus E-2224 for a small business, and want to add as much disk space as possible. I already have the older Gen10 with 4x4TB HDDs in RAID10 (effective capacity 8TB) and a 2TB SSD in the 5th slot (which is missing on the new G10 plus). The max stated capacity on the HPE site seems to be limited with their own enterprise HDDs, so I'd like to see if I can go for bigger disks. The server would be running a sort of an application which collects lots of data from devices, and the data tends to grow over time (1-2TB per year), and I'd prefer not to worry about the capacity for the next several years.
      My primary concern is the max capacity (max single drive capacity + max total RAID capacity with the Smart Array S100i) I can reliably install. If possible, some actual setup which has been shown to work with 32GB RAM and its limited 180W power supply? I was also planning on upgrading it to 32GB. If I am buying a 16GB RAM server, does this means it has both slots occupied with 8GB modules and I need a 2x32GB kit? For the os SSD, I won't have the PCIe slot available because we need to insert a certain GPS PCIe card that the server uses for time synchronization. So, if I want an SSD, this means I should use something like 1xSSD + 3xHDD in RAID5, instead of RAID10?
      I've been planning to install 16TB Seagate Exos X16 drives, with rated max operating power at 10W (6.3W for random reads/writes). Does this seam feasible?
      Thanks a lot for your tips!
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
