Similar Content
By JROrtiz
By Dave
Synology C2 Backup Now Available to US Customers
This is a data backup service that Synology released to EU customers last year. I remember trying to get it to install and it wouldn't take my CC# because of location. Fair enough, will it now and how much will it cost?
Seriously, how much is it? Ask Google and on March 25th, 2018 it's $14.12. That's still not a bad price for 100Gb of backup with versioning. Also not bad to consider this as a secondary cloud backup. (See below for pricing)
One thing to keep in mine this is a service that falls under Hyper Backup and not Cloud Sync. The two are very different. This will be a true back with versioning and not a simple synchronization of a folder in a cloud service like dropbox. Many a mistake have been made with sync pairs and cloud services! That won't happen with backup and versions.
Enable it and Back Up
In your Synology DSM go to Hyper Backup. Install if you are not using it. You would also use this app to backup to USB, Amazon S3, Microsoft Azure, etc.
Select Synology C2 Cloud Backup.
That should launch a login portal. If you have used Synology services before and have a login you can use those credentials or create credentials right here.
Start your free trial for 30 days but prices are still in POUNDS! That's a pound symbol right? If it was released to Europe why isn't it in Euros? I'm so confused. (it is Euro Dave! I had a brain fart on the Euro symbol. See response post below. Embarrassingly laughing at myself on this!)
It's here where it wouldn't let me proceed last time I tried due to it being a limited trial to EU customers only. You have to put your CC# in to get the 30 day free trial. It says i'm in the Europe Frankfort market but the purchase went through. So, does this mean if the US sinks into the Ocean and all my data goes with it, my photos will be in Frankfort safe and sound? Sweet!
This is the last web screen I see as it has now taken me back to Hyper Backup.
I'm going to choose a small amount to get started with.
I'm also going to limit the bandwidth of the backup and set Client Side encryption. The encryption password box will allow you to use the Admin account password so you don't forget what you put here unless your Admin password is less than 8 characters.
Once you are finished it will ask you if you want to backup now. I said now just to keep the network clean while I'm working but it will backup tonight. Look at the screen shot below. See the little arrow by Synology C2? That is the link to the web portal. It would be nice to see Synology integrate this into DSM so there isn't a secondary screen needed. It would also be nice to have some choice as to where your data is being sent and to be charged a proper amount. I'm afraid my bank might also charge me a fee for the Pounds to USD conversion. I'll update the post when I find out.
Here are the web portal screens below.
That's it. It works!
By Dave
Rachio has just announced version 3 of their popular sprinkler system controller. Rachio's generation 2 hardware was such an improvement on their first controller it may be hard to top. Gen 3 looks great and has new hardware to go with it. First Look video below!
Rachio's approach to irrigation hardware has been pretty straightforward.
Replace your existing irrigation controller, water smarter, take advantage of mobile to control it.
What they have done over the past 2 iterations is make it easier to do all three. Generation 2's hardware simplified the install immensely and the Rachio 3 Smart Sprinkler Controller looks to do the same as well as offering more options for the homeowner. So how do you improve on an already great controller?
Increase the smarts with enhanced weather data
Add a 5Ghz radio along with 2.4Ghz Wi-Fi
Add long range communication for add on devices
Let's just jump to the new devices. Rachio is announcing an add on flow meter called the Rachio Wireless Flow Meter. It will sense water flow and shut down water supply if it detects a leak.
This is an interesting addition to the product because it moves Rachio from a true DIY product to on that may need help from a professional. If you know your sprinkler system you know you have a back flow valve somewhere on your property. It is usually above ground and the Flow Meter can install in-line, after the backflow valve. Rachio has tips and guidance on the install if you would like to attempt it yourself but it may be prudent to involve your irrigation pro if you don't already have the tools to perform this type of work.
The "smarts" surrounding Rachio 3 cannot be overlooked. Their new weather intelligence is impressive. You can gain insight on weather data within a 36 foot radius of the Rachio 3 controller. Thirty Six Feet!
Rachio 3 ships April 2018 and can be pre-ordered today at http://www.rachio.com Rachio Flow ships May 2018. Pre-Sale pricing is $279 for the 8 Zone and Wireless Flow Meter. $329 for the 16 Zone and Wireless Flow Meter. Outdoor enclosures are still $29.
Flow Install Guidance - https://www.rachio.com/pdf/flow-install-overview_final.pdf
By ChappyEight
Okay, so I'll be moving in about a month to a different home and I'm trying to gather the necessary materials to set up a relatively extensive mixed home network. In order to simply get off the ground and get started, I've chosen the following pieces of equipment:
Modem: Our area is served by Spectrum and here's the list of the approved modems. Any suggestions on one of these? Router: Cisco RV320 Firewall Device: Do you recommend hardware here or use the router's software firewall? Switch: Cisco SG200 Access Point: Cisco Aironet 3602I Controller: Cisco 2504
So, I'm a complete novice when it comes to building a mixed home network that will eventually entail a server room, NAS, etc. However, I do know that I want all Gigabit equipment and the switch I chose is ginormous simply because I want the overhead to add connections later (IOW, I don't mind that it's overkill). Also, again just because I can, I'm looking to get primarily enterprise quality equipment. I'm not looking to burn money just to burn money, but I'm also not afraid to spend a little for a more quality network and something to learn on.
If I'm thinking correctly, I'll connect into the modem , then to the router, then to the firewall (if necessary), then to the switch, then have the controller in one of the switch ports and the POE AP in one of the POE ports on the switch. This, then, should give me both wired (by plugging Cat6a into the switch for other devices) and wireless access (via the AP), correct? Am I forgetting/missing something?
Really appreciate you entertaining this novice as I try to learn/build this network. You can see my ultimate goals here (Lofty, I know).
By Dave
The DS3018xs: Synology's first 6-bay tower NAS with optional 10GbE and NVMe SATA SSD supports. The Plus-series DS918+, DS718+, and DS218+: Designed to meet your intensive daily workloads the Value-series DS418: Featuring optimized 4K online transcoding capability
Synology® Inc. announced the official launch of new product lineup featuring:
· DS3018xs: Synology's first 6-bay tower NAS with optional 10GbE and NVMe SATA SSD supports
· Plus-series DS918+, DS718+, and DS218+: Designed to meet your intensive daily workloads
· Value-series DS418: Featuring optimized 4K online transcoding capability
To allow for ultra-high performance using SSD cache without occupying internal drive bays, DS3018xs features a PCIe slot, which can be installed with a dual M.2 SATA SSD adapter card (M2D17). DS918+ comes with dedicated dual M.2 NVMe slots at the bottom where you can directly install M.2 NVMe SSDs. DS418 features 10-bit H.265 4K video transcoding, and while supporting the next-generation Btrfs file system in DSM 6.2 official, expected to release in early Q1 next year. Btrfs provides reliable data protection through its cutting-edge self-healing and point-in-time snapshot features.
DS3018xs, Synology's first 6-bay tower NAS, is compact yet powerful as it features the Intel’s advanced Pentium D1508 dual-core 2.2GHz processor (Turbo Boost up to 2.6GHz) with AES-NI encryption engine; offering scalability of RAM up to 32 GB and storage capacity up to 30 drives with two Synology DX1215. In addition to four Gigabit LAN ports, DS3018xs takes advantage of boosting maximum throughput with an optional 10GbE network interface card, delivering stunning performance at over 2,230 MB/s sequential reading and 265,000 sequential read IOPS.
DS918+ and DS718+ are powered by Intel‘s Celeron® J3455 quad-core processor. DS218+ is powered by Intel’s Celeron® J3355 dual core processor. Both models are equipped with AES-NI hardware encryption engine and support up to two channels of H.265/H.264 4K video transcoding.DS918+’s RAM is scalable up to 8GB, while DS718+ and DS218+ are scalable up to 6 GB, allowing you to operate more intensive tasks at once. DS918+ and DS718+ are equipped with two LAN ports, and their storage capacity can be scaled up to 9 and 7 drives, respectively, with Synology’s DX517 expansion unit.
"Responding to the demands from our customers, DS3018xs is built as a comprehensive business-ready desktop NAS. Running mission-critical applications or planning virtualization deployment with DS3018xs has never been easier." said Katarina Shao, Product Manager at Synology Inc. "The new DS918+, DS718+, and DS218+ are optimized to be your digital video libraries, and will bring you an excellent viewing experience with high definition live video transcoding, regardless of device limitations."
DS418 is equipped with a 1.4GHz quad-core processor with hardware encryption engine, 2 GB RAM, and two LAN ports. Powered by the hardware transcoding engine, DS418 supports H.265 4K transcoding allowing it to serve as your media library. Combined with Btrfs and Snapshot supports, DS418 is delivers more efficient data storage and more reliable data protection.
For more information on DS3018xs, please visit https://www.synology.com/products/DS3018xs
For more information on DS918+, please visit https://www.synology.com/products/DS918+
For more information on DS718+, please visit https://www.synology.com/products/DS718+
For more information on DS218+, please visit https://www.synology.com/products/DS218+
For more information on DS418, please visit https://www.synology.com/products/DS418
Synology at a glance
Synology creates network-attached storage, IP surveillance solutions, and network equipment that transform the way users manage data, conduct surveillance, and manage networks in the cloud era. By taking full advantage of the latest technologies, Synologyaims to help users centralize data storage and backup, share files on-the-go, implement professional surveillance solutions, and manage networks in reliable and affordable ways. Synology is committed to delivering products with forward-thinking features and the best in class customer services.
