Similar Content
By oldwhs12
I have been running the WHS1 pack 3 for many years. Unfortunately it is no longer working. I got a Proliant microserver Gen10 hoping it will run it but was unable to install the software. The software should run on most older PCs?
Does anyone have the WHS1 running on the Gen10? Also my WHS1 iso is Pack 1. If I manage to install the Pack 1 can I find on the web the upgrade to pack 3? Would I be forever stuck at Pack 1? Any advice would be appreciated.
By AVsonyfan
Tips:
Just need to add your choice of SSDs and cable up to B120i port. I went with Samsung 860 Pro SSDs for the longer rated lifespan of write cycles.
By E3000
By E3000
Hey guys,
By hfournier
I'm putting together a build for a non-profit client and I want to make sure they're getting the best bang for their bucks.
Current server:
HP MicroServer N40L 8 GB WS2012E Plextor PX-256M5Pro SSD - OS drive SAMSUNG HD103SI 1TB (x2) - Data drives (Storage Spaces) WDC WD20EZRX 2TB (x2) - Data drives (Storage Spaces)
On the new server, I'd like to setup the OS on SSDs (RAID 1) for speed and redundancy. Trying to squeeze extra SSDs on the Gen 10 Plus lead me to using the PCIe card. I guess on the Gen 10 there's enough room and SATA connections to put a couple of SSDs in the Optical bay instead. And, I'm leaving 1 drive bay empty to add another 2 TB should they need it, which is not likely.
New Server Option 1 ($2084 CDN):
HP MicroServer Gen 10 X3418 (P07203-001) 8 GB 8 GB Module - DDR4 2400MHz (Kingston KTH-PL424E/8G) WS2016E StarTech.com Dual M.2 PCIe SSD Adapter Card - x8 / x16 Dual NVMe or AHCI M.2 SSD to PCI Express 3.0 - RAID & JBOD (PEX8M2E2) Samsung 970 EVO 500GB NVMe M.2 Internal SSD (MZ-V7E500BW) (x2) - OS Drives (RAID 1) WD Gold 2TB (x3) - Data drives (Storage Spaces, or can I RAID 5 them?)
New Server Option 2 ($2362):
HP MicroServer Gen 10 Plus (P16006-001) 16 GB WS2016E StarTech.com Dual M.2 PCIe SSD Adapter Card - x8 / x16 Dual NVMe or AHCI M.2 SSD to PCI Express 3.0 - RAID & JBOD (PEX8M2E2) Samsung 970 EVO 500GB NVMe M.2 Internal SSD (MZ-V7E500BW) (x2) - OS Drives (RAID 1) WD Gold 2TB (x3) - Data drives (Storage Spaces, or can I RAID 5 them?)
So two questions for all of you:
If anything, what would you change and why? For the extra $278 (13% more), is the Gen 10 Plus worth it?
Thanks.
