My First Review of HPE ProLiant Gen10 MicroServer BETA
Joe_Miner
1 hour ago, Trig0r said:
No shock on that one tbh..
anything else you can share?
The option of an iLo card is not possible as there are no hooks into the system board to support it. I had been researching AMD CPU and chipsets, as I thought at one time they had been working on something like Intel AMT, but no luck there. The solution folks are promoting some of the features of ClearOS as a remote access solution, VPN, Firewall, IDS, IPS and Gateway tools. I need to spend more time with ClearOS. HP is really promoting it on their platforms.
Still working on the ESXi stuff.
I'd never heard of clearOS before now tbh, sounds like it's a bit of a NAS type solution that you can then add stuff too, bit like the QNAP stuff...
Now there is a place left by HPE in the market for DELL or Lenovo to step in and make a server with cube form factor . Or folks buy Supermicro :)
So far i only saw few possitive comments about HPE Microserver Gen10 on the popular forums around the world.
Edited by FreeN@S
Can someone tell me if the DVD drive is standard size or slim like the Gen 8. Thanks
Should have looked closer its the same as the Gen 8
Edited by tezray
Found answer
It is 9.5mm. The retention clip is different than what is in the Gen8.
Sent from my LG-H910 using Tapatalk
Thank you it looks the same as the gen8 but nice to be confirmed
Shame we dont know someone who could maybe get some clips made up that screw to the back of a standard 9.5mm drive so it fits the Gen10...
    • BooyaK
      By BooyaK
      Hi all
      Apologies for hijacking a new thread as I couldn’t easily find an existing post which described this..
      I have an original HP Microserver N36L from 2012 that am Iooking to upgrade to a Gen 10 Plus.
      In the N36L I have added a Smart Array P410 with 256MB FBWC (via ebay) configured with 4 x 2TB WD Green drives with RAID5 (6TB logical) along with a 256GB SSD as a boot system drive in the ODD bay (with the BIOS mod of course) plus a PCIe x1 video card.
      The server is running Windows Server 2012 R2 but looking to uplift to 2019 (and maybe 2022 once it comes out) for general home enthusiast use mainly as a file server and to test VMs for labs.
      Am I able to “lift and shift” the drive array subsystem from the old to new server? I have done this on the DL380s in the past as the controllers and drives hold the RAID config.
      I guess I’m happy to get a new boot SSD if required (maybe boot issues between AMD and Intel CPU) but may have constraints mentioned below with the 5th interface.
      Have read from the various great posts by schoondoggy etc. that the P410 has issues with UEFI etc, so looking at a compatible option that’s not the “latest and greatest” eg something that can bought via ebay second-hand and relatively inexpensive (the E208i-p maybe stretching it…) and can of course read the existing RAID5 array config from the drives.
      Once moved across, I plan to progressively update them to larger HDD or SSDs and use the Smart Array expansion utility to expand the RAID-5 logical drive size once array rebuilds are complete.
      From what I understand I can’t add the 5th drive as there is no onboard NVMe or SATA connector. There is USB3 to boot off a thumb drive of course which is great for VMWare ESXi but maybe not for Windows…
      If I add the Smart Array card I guess it may limit my options as I understand it only has one PCIe x16 slot so can’t do both.
      Does anyone have any suggestions or other techniques (for example I’m not fussed with the expansion iLo slot but I think dedicated for that purpose only)?
      I have also looked at some of the great Servethehome reviews and benchmarks too but these are early 2020 and things may have evolved since then.
      Thanks in advance!
    • oldwhs12
      By oldwhs12
    • AVsonyfan
      By AVsonyfan
      Tips:
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
