My First Review of HPE ProLiant Gen10 MicroServer BETA
Joe_Miner
7 hours ago, FreeN@S said:
Now both Gen8 and N54l/40l/36l users hate Gen10 :D N54l/40l/36l was liked because they can fit 6 x 3,5" drives and have a RAIDZ2 array.
I work for >10.000+ enterprises , non of them bough Microserver Gen8. As you say, it did have features, but it is not a server for Enterprises.
Can you also test ZFS much liked IBM M1015 controller, to passthrough it to VM ?
Most N54l/40l/36l users that did not like MS Gen8 was due to the complexity of iLo, IP, B120i boot from ODD port.
M1015 is going to be a problem in the Gen10, due to the tab above the PCIe slots. The SFF-8087 connectors on a M1015 are directly under that tab facing up. It would be a very tight turn on the cable. I cant risk damaging the cable on the beta unit. Also in its current path the cable is too short to reach that far ahead. It may reach if I change the routing. As I found all of my M1015's were not going to work, I bought a HP H220 which is a LSI SAS 9205, in the picture below. For some reason the H220 did not see the drives I was testing. I switched to four Hitachi drives and it sees them. Wasted the better part of a day on that. I also seem to have a red LED on the motherboard now. I think I will be stripping it down and starting over fresh.
We've got 150+ Gen8 and a few remaining Gen7 (2 or 3) out and about in customer sites... we bought the RAC cards with the Gen7, and iLo Advanced with the Gen8. We used them to replace aging Dell and HP tower or rack servers (ML/DL, PowerEdge) and ran 2008 Core Hyper-V with a few guest machines... lack of iLo on Gen10 is a killer for us really, and we'd end up looking at towers again I think, even though the other main plus point was a tiny+quiet box that could live anywhere, and which didn't need a rack or a chunk of space.
Still want a Gen10 for home though, just because!
If I were still rocking the Gen8, I don't think I'd bother with the Gen10, even less so now I've got Frank.
Hopefully, we'll see a bit more direction from HPE with the Gen11/12 if they ever arrive, hopefully something with a socketted CPU is next, or, failing that maybe Dell/Lenovo or someone else will step into the hole HPE seem to have left..
M1015 will not work in the MS Gen10 due to cabling. LSI 9205 or 9207 would be good choices. If your card has connectors like the picture below it will not work with the cabling in the MS Gen10.
Waiting for info back from HPE. Everything in ESXi under pass-through is listed as 'not capable' including the H220 which I have run pass-through on other HP servers. Checked all BIOS settings everything seems to be in order. Checking for new BIOS or other direction from HPE development team.
On 6/10/2017 at 10:03 AM, yodafett said:
Schoondoggy, does esxi see a mirrored drive array,   I could see using it as an esxi box instead of a converted desktop with 3 mirrored arrays,  2 ssd arrays and 1 spindle storage array.  Could put esxi on the internal port,  at most add a 10gbe on pci slot.
The on board Marvell SATA controller uses software RAID and is not recognized by ESXi.
This suggest that maybe this APU is not capable of AMD IOMMU .  Lets see what HPE reply about that.
Quote
Had seen that in the first Review to. This stupid steel sheet just shrinks to Low Profile Cards ... there is no other reason ...
the Gen10 looks like a artificial shrink of possibilities against a lot of Users.
The Gen10 got his Usercases but it's not what it was before with low end shrink tech and wasted space.
Edited by Nomorlow
On 6/6/2017 at 9:49 AM, schoondoggy said:
John and I are the only two I am aware of in the Reset forum. From what I have heard they sent several units to application specif partners,
The 6th SATA port is about the only thing I can think of that may be in question.
There will be 5 SATA ports on the production MS Gen10.
    • BooyaK
      By BooyaK
      Hi all
      Apologies for hijacking a new thread as I couldn’t easily find an existing post which described this..
      I have an original HP Microserver N36L from 2012 that am Iooking to upgrade to a Gen 10 Plus.
      In the N36L I have added a Smart Array P410 with 256MB FBWC (via ebay) configured with 4 x 2TB WD Green drives with RAID5 (6TB logical) along with a 256GB SSD as a boot system drive in the ODD bay (with the BIOS mod of course) plus a PCIe x1 video card.
      The server is running Windows Server 2012 R2 but looking to uplift to 2019 (and maybe 2022 once it comes out) for general home enthusiast use mainly as a file server and to test VMs for labs.
      Am I able to “lift and shift” the drive array subsystem from the old to new server? I have done this on the DL380s in the past as the controllers and drives hold the RAID config.
      I guess I’m happy to get a new boot SSD if required (maybe boot issues between AMD and Intel CPU) but may have constraints mentioned below with the 5th interface.
      Have read from the various great posts by schoondoggy etc. that the P410 has issues with UEFI etc, so looking at a compatible option that’s not the “latest and greatest” eg something that can bought via ebay second-hand and relatively inexpensive (the E208i-p maybe stretching it…) and can of course read the existing RAID5 array config from the drives.
      Once moved across, I plan to progressively update them to larger HDD or SSDs and use the Smart Array expansion utility to expand the RAID-5 logical drive size once array rebuilds are complete.
      From what I understand I can’t add the 5th drive as there is no onboard NVMe or SATA connector. There is USB3 to boot off a thumb drive of course which is great for VMWare ESXi but maybe not for Windows…
      If I add the Smart Array card I guess it may limit my options as I understand it only has one PCIe x16 slot so can’t do both.
      Does anyone have any suggestions or other techniques (for example I’m not fussed with the expansion iLo slot but I think dedicated for that purpose only)?
      I have also looked at some of the great Servethehome reviews and benchmarks too but these are early 2020 and things may have evolved since then.
      Thanks in advance!
    • oldwhs12
      By oldwhs12
    • AVsonyfan
      By AVsonyfan
      Tips:
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
