My First Review of HPE ProLiant Gen10 MicroServer BETA
Joe_Miner
Rethinking about this box.  Maybe instead of comparing it to the gen8 we compare it to the qnaps and synologys in the same price bracket. With the clearOS, it seems to hit as more of a cross between the NAS and the mediasmart servers.  Especially  against like a qnap 451+ with both having video out, Plex, etc.
9 hours ago, schoondoggy said:
Sorry, life got in the way of fun! Up and running ESXi from a USB drive. I have a SSD on SATA Port5 and a small HD on SATA Port6. I will put four drives in the bays and try to pass through the Marvell controller to a VM. I will start a new thread to discuss ESXi on the MS Gen10:
Schoondoggy, does esxi see a mirrored drive array,   I could see using it as an esxi box instead of a converted desktop with 3 mirrored arrays,  2 ssd arrays and 1 spindle storage array.  Could put esxi on the internal port,  at most add a 10gbe on pci slot.
it is still interesting to see how it will work with ESXi, devices passtrough and etc.
but for a little more, you can configure yourself future proof Supermicro mini-ITX box with Xeon D-1521 4core/8threads which can hold up to 128GB RDIMM ECC or 64GB UDIMM ECC.
you will also get 2x 10GBe, M.2 slot, 6x6Gbps SATA3 and IPMI.
priced around 500eur :  X10SDV-4C-TLN2F  + SC721TQ-250B beautifull chasis for another 150eur.
Gen10 is step back, but pricey. Can't imagine myself paying 666eur for a AMD SoC  and low end features..
Thanks for review! However, I'm very disappointed. My personal feel is, that this is a watered down, step back version, so they get better price margins. Even simple things like front mask, is poorer. Gen8 lockable front mask is more than awesome, why change it, with slap just the plastic on?
I'm also not big fan of AMD, I would have liked to see Xeon in there, and what's even worse CPU cannot be changed if I understand it well.
All that and no ILO, just make it a plain small factor PC with ECC memory.
Probably better deal would be to buy mini ITX from (e.g. EPC612D4I - Xeon E5-2600 , 64GB ECC DDR4 2400 RAM), find appropriate ITX box and be done with it. Much greater flexibility. And there is IPMI 2.0, which is similar to ILO.
I don't get it. Gen8 is awesome, people love it, it's cool it's great, you don't need to be a genius, or do fancy market research, (just read this forum) to see that people adore it. Just improve it, don't dumb it down. It doesn't make sense... For me decision to do this would be the same as if Apple, would dumb down iPhone to blackberry.
It all depends on your use case. A lot of MS N54l/40l/36l users hated the MS Gen8. The MS Gen8 did have the features of HPE Enterprise class servers, but I do not think many Enterprise customers bought it. HPE did a lot of work to position the MS Gen8 as a remote office server that could be managed from the Data Center, but I do not think many customers deployed it that way. I have to believe that some of their biggest customers advised them on features they wanted to see in a new MS Gen10. The MS Gen10 is a very different server than the MS Gen8 was. Time will tell if it is a hot or a miss.
I will try it and see what happens.
Now both Gen8 and N54l/40l/36l users hate Gen10 :D N54l/40l/36l was liked because they can fit 6 x 3,5" drives and have a RAIDZ2 array.
I work for >10.000+ enterprises , non of them bough Microserver Gen8. As you say, it did have features, but it is not a server for Enterprises.
Can you also test ZFS much liked IBM M1015 controller, to passthrough it to VM ?
Edited by FreeN@S
    • BooyaK
      By BooyaK
      Hi all
      Apologies for hijacking a new thread as I couldn’t easily find an existing post which described this..
      I have an original HP Microserver N36L from 2012 that am Iooking to upgrade to a Gen 10 Plus.
      In the N36L I have added a Smart Array P410 with 256MB FBWC (via ebay) configured with 4 x 2TB WD Green drives with RAID5 (6TB logical) along with a 256GB SSD as a boot system drive in the ODD bay (with the BIOS mod of course) plus a PCIe x1 video card.
      The server is running Windows Server 2012 R2 but looking to uplift to 2019 (and maybe 2022 once it comes out) for general home enthusiast use mainly as a file server and to test VMs for labs.
      Am I able to “lift and shift” the drive array subsystem from the old to new server? I have done this on the DL380s in the past as the controllers and drives hold the RAID config.
      I guess I’m happy to get a new boot SSD if required (maybe boot issues between AMD and Intel CPU) but may have constraints mentioned below with the 5th interface.
      Have read from the various great posts by schoondoggy etc. that the P410 has issues with UEFI etc, so looking at a compatible option that’s not the “latest and greatest” eg something that can bought via ebay second-hand and relatively inexpensive (the E208i-p maybe stretching it…) and can of course read the existing RAID5 array config from the drives.
      Once moved across, I plan to progressively update them to larger HDD or SSDs and use the Smart Array expansion utility to expand the RAID-5 logical drive size once array rebuilds are complete.
      From what I understand I can’t add the 5th drive as there is no onboard NVMe or SATA connector. There is USB3 to boot off a thumb drive of course which is great for VMWare ESXi but maybe not for Windows…
      If I add the Smart Array card I guess it may limit my options as I understand it only has one PCIe x16 slot so can’t do both.
      Does anyone have any suggestions or other techniques (for example I’m not fussed with the expansion iLo slot but I think dedicated for that purpose only)?
      I have also looked at some of the great Servethehome reviews and benchmarks too but these are early 2020 and things may have evolved since then.
      Thanks in advance!
    • oldwhs12
      By oldwhs12
    • AVsonyfan
      By AVsonyfan
      Tips:
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
