My First Review of HPE ProLiant Gen10 MicroServer BETA
Joe_Miner
So, just out of interest how many of you guys here actaully have one of these Beta units, and what do we think, other then SATA6 will change between now and the actual release unit?
can anyone with a beta unit compare/contrast the ease of "operating" on it to add pci-e cards / change memory etc relative to earlier microserver generations?
thanks
John and I are the only two I am aware of in the Reset forum. From what I have heard they sent several units to application specif partners,
The 6th SATA port is about the only thing I can think of that may be in question.
3 hours ago, JackoUK said:
I agree with your 3-way use-case assessment ... and would like to know how the G10 performs as a 4K video streamer.
HP are citing this as a use-case too but the displayports are only rev. 1.2 which I believe is limited to a 60/75 Hz refresh rate, New TV's have moved up to 120Hz.
https://www.hpe.com/h20195/v2/GetDocument.aspx?docname=a00008776enw&doctype=Solution
If you don't own a 4K TV then I'll understand why you can't do the test!
I am embarrassed to say I don't have a 4K TV yet!
tbh, the more I think about how much I used iLO vs ditching the onboard Matrox GPU (if you could call it a GPU) the only think that does bother me is them going back to soldered CPU's, one of the greatest strenghts of the Gen8, imho, was the ability to buy it cheap, get it up and running, then upgrade it as and when needed..
I've had the luxury of knowing about this release for a while and I've gathered a few thoughts on it but my main one is this. The Gen 10 feels like a "brother" box to the Gen 8. I think they should have released both at the same time honestly.  One is the Enterprise box, ILO, upgradeable, etc. and the other is slightly less yet still powerful enough.  I personally don't need ILO and all of those options of RAID cards and such.  I do however, greatly appreciate having the option of a slightly upgradeable box that will serve my home needs.  I would love to have a Gen 10 to try to use as my Plex server and maybe a camera server. Perhaps even replace my NAS.
I see it as an add-on and not so much of a replacement.  I don't know if HP will agree with me but there it is! I hope the Gen 8 has a good healthy life beyond the 10.  I would also hope for some good price cuts for you guys! My 2 cents.
The features of the MS Gen10 make it a nice fit for a SMB commercial surveillance server and security viewing station all in one. Pair it up with Milestone software, cameras and two monitors.
I can totally see that.  Do you see it as an "add-on" server for the SMB and mid size business channel? We need a box to do "x," but don't want to invest thousands of dollars to do so.  Upgrade in the future perhaps.
Just wanted to say thanks to @Joe_Miner and @schoondoggy for this great coverage of the Gen 10. Love the videos John. No clue that you were an engineer in past life!
#detail
Last comment/question, where does the #RESET sticker go on the Gen 10?
    • BooyaK
      By BooyaK
      Hi all
      Apologies for hijacking a new thread as I couldn’t easily find an existing post which described this..
      I have an original HP Microserver N36L from 2012 that am Iooking to upgrade to a Gen 10 Plus.
      In the N36L I have added a Smart Array P410 with 256MB FBWC (via ebay) configured with 4 x 2TB WD Green drives with RAID5 (6TB logical) along with a 256GB SSD as a boot system drive in the ODD bay (with the BIOS mod of course) plus a PCIe x1 video card.
      The server is running Windows Server 2012 R2 but looking to uplift to 2019 (and maybe 2022 once it comes out) for general home enthusiast use mainly as a file server and to test VMs for labs.
      Am I able to “lift and shift” the drive array subsystem from the old to new server? I have done this on the DL380s in the past as the controllers and drives hold the RAID config.
      I guess I’m happy to get a new boot SSD if required (maybe boot issues between AMD and Intel CPU) but may have constraints mentioned below with the 5th interface.
      Have read from the various great posts by schoondoggy etc. that the P410 has issues with UEFI etc, so looking at a compatible option that’s not the “latest and greatest” eg something that can bought via ebay second-hand and relatively inexpensive (the E208i-p maybe stretching it…) and can of course read the existing RAID5 array config from the drives.
      Once moved across, I plan to progressively update them to larger HDD or SSDs and use the Smart Array expansion utility to expand the RAID-5 logical drive size once array rebuilds are complete.
      From what I understand I can’t add the 5th drive as there is no onboard NVMe or SATA connector. There is USB3 to boot off a thumb drive of course which is great for VMWare ESXi but maybe not for Windows…
      If I add the Smart Array card I guess it may limit my options as I understand it only has one PCIe x16 slot so can’t do both.
      Does anyone have any suggestions or other techniques (for example I’m not fussed with the expansion iLo slot but I think dedicated for that purpose only)?
      I have also looked at some of the great Servethehome reviews and benchmarks too but these are early 2020 and things may have evolved since then.
      Thanks in advance!
    • oldwhs12
      By oldwhs12
    • AVsonyfan
      By AVsonyfan
      Tips:
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
