Components & Specs of the Gen10 MicroServer BETA Unit Tested
Joe_Miner
    • BooyaK
      By BooyaK
      Hi all
      Apologies for hijacking a new thread as I couldn’t easily find an existing post which described this..
      I have an original HP Microserver N36L from 2012 that am Iooking to upgrade to a Gen 10 Plus.
      In the N36L I have added a Smart Array P410 with 256MB FBWC (via ebay) configured with 4 x 2TB WD Green drives with RAID5 (6TB logical) along with a 256GB SSD as a boot system drive in the ODD bay (with the BIOS mod of course) plus a PCIe x1 video card.
      The server is running Windows Server 2012 R2 but looking to uplift to 2019 (and maybe 2022 once it comes out) for general home enthusiast use mainly as a file server and to test VMs for labs.
      Am I able to “lift and shift” the drive array subsystem from the old to new server? I have done this on the DL380s in the past as the controllers and drives hold the RAID config.
      I guess I’m happy to get a new boot SSD if required (maybe boot issues between AMD and Intel CPU) but may have constraints mentioned below with the 5th interface.
      Have read from the various great posts by schoondoggy etc. that the P410 has issues with UEFI etc, so looking at a compatible option that’s not the “latest and greatest” eg something that can bought via ebay second-hand and relatively inexpensive (the E208i-p maybe stretching it…) and can of course read the existing RAID5 array config from the drives.
      Once moved across, I plan to progressively update them to larger HDD or SSDs and use the Smart Array expansion utility to expand the RAID-5 logical drive size once array rebuilds are complete.
      From what I understand I can’t add the 5th drive as there is no onboard NVMe or SATA connector. There is USB3 to boot off a thumb drive of course which is great for VMWare ESXi but maybe not for Windows…
      If I add the Smart Array card I guess it may limit my options as I understand it only has one PCIe x16 slot so can’t do both.
      Does anyone have any suggestions or other techniques (for example I’m not fussed with the expansion iLo slot but I think dedicated for that purpose only)?
      I have also looked at some of the great Servethehome reviews and benchmarks too but these are early 2020 and things may have evolved since then.
      Thanks in advance!
    • oldwhs12
      By oldwhs12
    • AVsonyfan
      By AVsonyfan
      Tips:
    • E3000
      By E3000
    • E3000
      By E3000
      Hey guys,
