Fan speed stuck at 13%
JBCn1
Hello,
My microserver is stuck on 13% fan speed and it wont go lower.
The CPU is 40C and a mate, who own the same server, got a fan speed at 9%.
I think mine is abit too noisy, so I would really like to get the fan speed down, but I can't.
Thinks i have tried:
Tried all tree raid controller modes.
Power regulator Setting set to "OS Control Mode"
Its brand new, and its updated.
BIOS: J06 11/02/2015
iLO Firmware Version  2.50 Sep 23 2016
Harddrives:
1 x 3TB WD Red
1 x 2TV WD Red
OS:
Unraid
I have read alot about it and I can't find the solution - other got it fixed by updating bios and by selecting another raid controller, but it doenst work for me :)
Anyone got something I can try?
Best regrads
Jacob
Edited by JBCn1
Do you see 04-HD Max temp sensor in ILO?
I had Debian installed in ahci mode, but ilo would not detect the hard drive temp, a simple switch to centos + the b120i raid controller driver fixed my issue.
Edited by Mathias
+1 the problem is is with 04-HD Max sensor. If ILO doesn't detect it it will set the mininum speed to 13-14% depending on the ambiance temporature. If the ambience temperature goes up to 28C as he does here sometimes. it will go up to 21% easly.
I was on ubuntu too. Changed to cent os and it's now running at 6-9% max. Move any ios wirh b120i supported drivers and you're fine!
Cheers.
