ATX 2x8PIN rail power supplies
JessicaMartin
Just bought the following SUPERMICRO MOTHERBOARD X9DRi-LN4F+ with two e5-2560s and I noticed that it takes 2x8PIN power rails.
Where do I find a power supply that is ATX based that offers that?
  • 3 weeks later...
Generally, you won't.  For the most part, you need a server power supply to support this natively.  And these get expensive, fast.
The connector type (the 8 pin connector on the motherboard) is called an "EPS" connector, in case it helps in your searches.
You can find Molex to EPS adapters, though.  But remember to find and buy good quality parts here.
A decent example is: https://www.amazon.com/dp/B00OSR3V84/
  • 2 years later...
sadly even the molex connectors tend to be less plentiful on power supplies these days
