B140i Smart Array Driver Issue? ml30
sokalskiy
Sorry for my English)
Hi all!
I think the problem seems to be affecting write performance to ssd disks.
Reading speed is 700 MB/s but writing speed is 43 MB/s. (raid driver 62.12.0.64, windows server 2012 r2)
Someone knows the solution??
One guy said that previous driver (62.0.0.64) works well, but this driver can not be installed
Edited by sokalskiy
Is it one SSD? or multiple SSD's?  RAID0? What SSD's are you using?
Check this post:
and it's thread -- looks like it's a duplicate of what you are experiencing...........
Port 1 - SSD 1
Port 2 - SSD 2
Port 3 - HDD 1
Port 4 - HDD 2
SSD - Reading speed is 700 MB/s, writing speed is 43MB/s
HDD - Reading speed is 260 MB/s, writing speed is 180 MB/s
Ports 5,6 - empty
Edited by sokalskiy
I do not believe that you guys are not using B140i for SSD's and
I do not believe that writing speed is more faster 60-80 MB/s (Exception is HP disks)
Write who what uses and write performance.
Thanks!
Currently, with a Samsung 840 Pro on Port5 I'm getting ~500 Read & ~150-160 Write with CDM,
With a RAID0 of 4 VelociRaptors in Ports1-4 I was getting ~700 READ & 140 Write with CDM then I turned on Cache in SSA and my Write speed jumped to about 650-700 for the RAID0 VR's but didn't change for the SSD
In Port6 I have a 1TB VR in RAID0 with ~200Read & 200Write
Last year I had two SSDs in Ports 1 & 2, each in a RAID0, and both were showing Read & Writes of ~500 each after changing setting in SSA for the B140i
I need to spend more time reading up and messing with the SSA settings I think for the B140i.
This is what I was seeing before enabling Write Cache in B140i for the 4 VR's in RAID0
2017-04-15%204%20WD%20250GB%20VRs%20RAID
After enabling Write Cache I saw this for the 4VRs
2017-05-11%204%20WD%20250GB%20VRs%20RAID
And for the SSD on Port 5
2017-05-11%20OS%20Port5%20Samsung%20840%
And the VR on Port 6
Not sure why this is happening -- last year when I had SSDs and I enabled Write Cache I was getting full Write performance from the Samsung SSDs
I'm still messing with the settings in the B140i to see what happens -- would appreciate any one's ideas on this
