Storage Question
cupcake
Morning guys,
I got my previous question resolved once I got the floppy to sata cable, and used my 2.5" drive to load windows 10 on to. All now working great and been flying for a few weeks now.
I've just upgraded my storage though and have a question.
I've got 4 x WD Green 2TB drives installed.
I've gone through the B120i setup and set up a new logical drive using all 4 physical drives in a RAID 1+0 setup, which should leave me with around 4TB of usable storage.
That's all gone fine.
When I've gone into Windows, the drives obviously aren't ready for use there, so I've gone into Disk Management to format the drives to make them usable, however I'm seeing them as 2 seperate blocks of storage, rather than one block of unalloacted space.
Is this normal?
If I just format both blocks, can I then merge them into one?
Oh, and if you are using greens change the idle time on them or they'll fail smart tests as they park the heads too often..
Sent from my SM-A520F using Tapatalk
8 minutes ago, Trig0r said:
Sorry, I mean when you have created the partition..
You mean when setting up the array?
I followed the setup process to setup a new array and selected all 4 drives to create the logical drive.
I can go back and double check the setup tonight though to make sure.
Thanks for that.
I wasn't aware of that issue.
Where you have the 2tb partition, right click on it, and presuming it's empty and you haven't started moving data, delete the volume, then once it's gone you should see a 4tb free space, right click and create a new volume, and use the whole disk, should work..
Thanks for the quick replies.
Just tried this and still seeing the 2 volumes of unallocated space
I can create a new simple volume on the 2TB space, but the other space just has properties and help available when I right click on it.
    • Giuseppolino87
      By Giuseppolino87
      Hi everyone, today I wanted to install esxi 6.7 to try out the various functions, my question is the following, I have a server where I have installed esxi in an SSD and I have two other 4 tb disks so 8 tb total.  I would like to make sure that when I create a virtual machine in this case I will install the various virtual machines in the SSD and use the two disks for data.  So how can I do this?  Thank you very much for those who can help me.
    • E3000
      By E3000
      Hey guys,
      So far my list is as follows:
      Date formated as DD/MM/YYYY.
    • E3000
      By E3000
      Looking for a quick answer here from someone in the know...
      I upgraded some of the internals of my Gen8 server and at the same time I did a BIOS reset as I had forgotten the password that I had set years ago. When booting back up the upgraded hardware was detected and fine but I received Error 1784 - Drive Array - Logical Drive Failure. I believe this is due to a setting change in the BIOS and not anything hardware related. I have gone into IP/SSA and see the array needs to be rebuilt. I had all drives configured as single RAID0. It says all data will be lost if I reconfigure this but I remember reading somewhere on here that the data will be fine if I reconfigure as RAID0.
      I do have a backup of course, but it’s not a high availability mirror and will take some time to get back the way I had it, so just want to know if it’s safe to reconfigure the RAID0 without erasing the drives. I have tried pulling the drives out and connecting them to another PC and they are fine. Can anyone tell me which options to choose to get these back to normal and remove the flashing red light?
      Thanks 😶
    • E3000
      By E3000
      Hello all,
      A few questions for those who use Type-1 Hypervisors on their Gen8 MicroServers...
      I am looking to try ESXi or ProxMox and have been reading a lot of the threads on here.
      Hopefully you guys can help with some harder to find answers I have been seeking.
      1) Which would be the better way to setup ProxMox:
           a) Hypervisor on Internal MicroSD, VMs installed on SSD in ODD Port, Data on 4x HDDs in bays.
           b) Hypervisor on Internal USB, VMs installed on SSD in ODD Port, Data on 4x HDDs in bays.
           c) Hypervisor and VMs both installed on same SSD (partitioned?) in ODD Port, Data on 4x HDDs in bays.
           d) Hypervisor on SSD using a USB-to-SATA cable on Internal USB, VMs installed on separate SSD in ODD Port, Data on 4x HDDs in bays.
      2) Would a 128GB SSD be a ‘waste‘ for installing a Hypervisor on? How much space is typically needed?
      3) How many VMs have you guys run on a Gen8 comfortably without it being sluggish?
      4) Everyone seems to be going RAID crazy these days. Is there any reason to use it if high-availability is not that necessary and a good backup plan is in place? What is wrong with separate disks (or singular Raid0s)?
      5) Does using Type-1 Hypervisors have any effect on the internal fans speed/noise? Is it possible to have 3-5 VMs running and still have the fan speed @~8% as it was when I was using 2 nested (Type-2) VMs?
      Sorry in advance if some of these questions are silly, common knowledge, or “depends on what you are doing in the VMs!” 😆
      Thanks in advance to all those that help!
    • Angelus
      By Angelus
      Good day all
      i bought a gen 10 x3216 MicroServer and I have been trying to install windows server 2016 on it with a usb and I get it to boot into the usb with the iso on it but I can not get past the one install step where u supposed to select the drive.
      instead it says to download storage drivers and browse to select driver. I have downloaded every single storage driver from the hpe site or is sure does feel like it.
      if I try to select the driver I have to do so manually by unticking show only compatible drivers because if I leave it ticked there is nothing compatible. Iam stumped on what the correct driver is.
      ok so what Iam trying to do isssssss I want to install the os onto the usb that I have attached inside the box the one that is directly coming off the board. Is that a different driver ?
      In bios/boot up options I can see all usb connected.
      can anyone please help me with this
