tezray 10 Posted April 4, 2017 Share Posted April 4, 2017 Hi since I bought a new motherboard for my pc server I cannot pass my hd 7870 through to a vm anymore without the vm crashing constantly on startup. I have installed Windows 10 and was about to start using hyper-v but I just don't like it. Then I saw Xenserver has anyone used it a lot and think it is a good option and easy to use. I am terrible with Linux but am hoping people say it's a doddle it has a lot of gpu passthrough support but I noticed it doesn't have a section here in virtualisation so maybe it is not that good Sent from my SM-G935F using Tapatalk Link to post Share on other sites
tezray 10 Posted April 5, 2017 Author Share Posted April 5, 2017 Well when I added a second gpu it passed through the card to the Xenserver I got half way through installing a win 10 vm and then switched it off I don't like that you need to use Linux commands to add hard drives how rubbish and it completely put me off the software it should be in the gui oh well otherwise it looked good. I am just too scared if something goes wrong I won't be able to fix it using commands Sent from my SM-G935F using Tapatalk Link to post Share on other sites
schoondoggy 895 Posted April 5, 2017 Share Posted April 5, 2017 Have you looked at any of the KVM builds? Link to post Share on other sites
