aussy Posted January 30, 2017 Share Posted January 30, 2017 OK...I have a question.... I am just starting to get into the smart home thing and have already run into a road block. I want to use the Amazon Echo for control of things like speakers, lights, ceiling fans, etc. I do not want to use a system requiring any sort of dedicated hub. I have an Echo dot connected to a bluetooth speaker plugged directly into an outlet. That works great!! I also have a TP-Link HS105 connected that works perfect with the Echo/Alexa..... Here's my question: I have a ceiling fan with a light in it that is controlled from two wall switches. One switch turns that fan on/off, the other turns the light on/off. I can not find a smart double wall switch that works without a hub and is compatible with Alexa/Echo. Any suggestions?? Link to comment Share on other sites More sharing options...
