Mirson 0 Posted November 23, 2016 Share Posted November 23, 2016 What do we have: 1. Plugs - Zooz Z-Wave Plus Mini Plug On / Off Module ZEN07, Cert. #ZC10-16085170 - 3 items; 2. Wink Hub 2 - 1 item; 3. Plugs are connected to Wink Hub 2. What do we need: 1. To have a wired (or battery powered) ON/OFF switch with 3 or 4 buttons, which will control these plugs through the Wink Hub 2; 2. This switch should fit the rocker size plate and be in light almond color. I would be grateful for advice from experienced specialists. Link to post Share on other sites
JROrtiz 36 Posted March 14, 2017 Share Posted March 14, 2017 What do we have: 1. Plugs - Zooz Z-Wave Plus Mini Plug On / Off Module ZEN07, Cert. #ZC10-16085170 - 3 items; 2. Wink Hub 2 - 1 item; 3. Plugs are connected to Wink Hub 2. What do we need: 1. To have a wired (or battery powered) ON/OFF switch with 3 or 4 buttons, which will control these plugs through the Wink Hub 2; 2. This switch should fit the rocker size plate and be in light almond color. I would be grateful for advice from experienced specialists. I know this post is quite old but in case you're still looking, the Lutron Connected Bulb Remote is a great accessory to the Wink Hub. It will fit in a standard wall plate (requires Lutron adapter) and the four buttons can be programmed to trigger shortcuts on the Wink Hub. Pricey at $30, but extremely flexible and good looking. Link to post Share on other sites
Mirson 0 Posted March 14, 2017 Author Share Posted March 14, 2017 (edited) I know this post is quite old but in case you're still looking, the Lutron Connected Bulb Remote is a great accessory to the Wink Hub. It will fit in a standard wall plate (requires Lutron adapter) and the four buttons can be programmed to trigger shortcuts on the Wink Hub. Pricey at $30, but extremely flexible and good looking. Thank you for your answer, but we've already tried this remote and it can't communicate with these Z-wave plugs through Wink hub. Edited March 14, 2017 by Mirson Link to post Share on other sites
