Devi8 0 Posted January 28, 2016 Share Posted January 28, 2016 does anyone have experience with this? I want to know which one is the best and can you program it via the app? Link to post Share on other sites
Dewain27 0 Posted February 9, 2016 Share Posted February 9, 2016 So, I have had both the Radio Thermostat (AKA the IRIS branded one) and the one I have in my new home is the Go Control. Both program the same way and yes it is all through the app. Interestingly enough... all of the built in stuff is useless once you get it connected to Iris. Iris is just taking care of all the scheduling. The termostat just sends data back to Iris and all the logic is then in Iris. Link to post Share on other sites
cgrossmeier 0 Posted February 22, 2016 Share Posted February 22, 2016 Right now, I don't trust the Hub to report temp correctly and act on any events. I am getting old Gen1 devices reporting the temp as -1F inside the home. The last thing I need is for Lowe's to push an update and break a sensor and cause my home to either shut off or run constantly while I am away. Link to post Share on other sites
Devi8 0 Posted February 29, 2016 Author Share Posted February 29, 2016 I have 3 radio ct101s they work flawless on a next Gen hub Link to post Share on other sites
