Dave 435 Posted November 21, 2015 Share Posted November 21, 2015 I've stumbled across something pretty cool in the SmartThings community. I dare call it a forum because it needs some help in that regard. It's called Rule Machine. I've always wanted a way to do two or more qualificatilons then do an action. Like IFTTT but with an extra "This." If This and This, then do an action. Rule machine looks like it will do it. https://community.smartthings.com/t/release-rule-machine/28730 Now, if we could only get ST or the Rule Machine owner to embrace a forum where different questions can be asked and we can categorize discussions! Right now, the support/announcment thread of Rule Machine is 546 comments long. Rule MachineRule Machine is a generalized rule engine for SmartThings. It allows you to predicate actions to be taken in SmartThings by a logical rule based on specified conditions of your system.What are rules?A rule is a method of specifying certain conditions and their truth relationships in order to cause some action to take place in SmartThings. For example, one person posed this case: Suppose my presence or my wife’s presence is home, there is motion in the bedroom, it’s between 8 PM and 11 PM, and the temperature is below 65 — if those conditions are met, turn on the electric blanket. In order for this action to take place in SmartThings, based on those conditions, a SmartApp will need to evaluate those conditions, and if they are met, cause the action. Rule Machine is a SmartApp that allows you to specify the conditions, the rule they must meet, and the desired action to take place.What are conditions?Rule Machine allows a wide range of possible conditions to be specified. In particular, the following capabilities in a SmartThings system can be tested. Each condition is one such test. The supported capabilities and states to be tested are the following:Acceleration: active / inactiveBattery: = != < > <= >= relative to a numberCertain time: at a specified time, including sunrise / sunset with offsetContact: open / closedDays of week: [Monday, Tuesday, Wednesday, Thursday, Friday, Saturday, Sunday]Dimmer level: = != < > <= >= relative to a numberEnergy meter: = != < > <= >= relative to a numberHumidity: = != < > <= >= relative to a numberIlluminance: = != < > <= >= relative to a numberLock: locked / unlockedMode: [ any of your location’s modes ]Motion: active / inactivePower meter: = != < > <= >= relative to a numberPresence: present / not presentSwitch: on / offTemperature: = != < > <= >= relative to a numberTime of day: between two times, including sunrise / sunset with offsetsValve: open / closedWater sensor: dry / wetFor each device capability, one or more devices can be selected, and the device state required for the condition to be met is selected. When multiple devices are selected, the condition may apply for ANY (default) or ALL of the devices. For example, the conditions for the electric blanket case are, my presence or my wife’s presence is present (ANY)bedroom motion is activetime of day is between 8:00 PM and 11:00 PMbedroom temperature is < 65 Limitation: a rule may only have at most one each of Days of week, Mode, Certain Time, or Time of day as conditions. If you need logic for two different Time of day periods, that would have to be done in two separate rules.How is a rule defined?A rule is a logical expression built up using the conditions and the two logical operators AND and OR, along with parenthesized sub-rules, each of which is itself a logical expression. A logical expression defines the logical relationship between the various conditions. In order to decide if the end action should be taken or not, Rule Machine evaluates the truth of the defined rule. In the electric blanket case, we have a very simple rule: my presence or my wife’s presence is present ANDbedroom motion is active ANDtime of day is between 8:00 PM and 11:00 PM ANDbedroom temperature is < 65 There can be more complex rules than this. Suppose we want the same basic rule, but want it to apply if either bedroom motion is active or the bedroom door is closed. We would add the additional condition of “bedroom door is closed”. That rule would be this: my presence or my wife’s presence is present AND(bedroom motion is active OR bedroom door is closed) ANDtime of day is between 8:00 PM and 11:00 PM ANDbedroom temperature is < 65 In this example, we have used parentheses to group two conditions into a sub-rule: (bedroom motion is active ORbedroom door is closed). Rule Machine allows arbitrarily complex rules to be defined, with parentheses used to group conditions into sub-rules. To use this feature of sub-rules in parentheses, you must first turn on the "Advanced Rule input" option, found under More Options at the bottom of the main page. It allows nested sub-rules to any depth, and it allows any number of conditions. To help you see exactly the rule you are building, Rule Machine displays the partial rule at each step as you define it. See screen shots in a following post. Rule Machine is a fully generalized rule engine. The logical expression can be described as a sequence of terms, separated by operators, where each term is either a condition or a parenthesized sub-rule (available with Advanced Rule input enabled, under More Options), and the operators are AND and OR. There is no need in Rule Machine for a NOT operator, because each condition can be stated in the negative. The evaluation of a rule or sub-rule is strictly left to right. If at any point in the evaluation, the truth value preceding an AND operator is false, the sub-rule or the rule itself is false without further evaluation. Similarly, if the truth value preceding an ORoperator is true, the sub-rule or the rule itself is true without further evaluation. For those familiar with coding, there is no operator precedence. Each rule or sub-rule may have as many terms as desired.Rule EvaluationOnce Rule Machine is installed with conditions, rule, and actions, what happens next? Whenever something happens in SmartThings that could affect the conditions, Rule Machine evaluates the rule to see if it is true orfalse. If it becomes true, then it will take some selected actions; if it becomes false, it can take some other selected actions. In the case of the electric blanket, the rule would be evaluated whenever any of the following things happen: the state of my presence or my wife’s presence changesthe bedroom motion goes active or inactivethe bedroom door is opened or closedthe time becomes 8:00 PM, or becomes 11:00 PMthe bedroom temperature is reported Since our rule for this case involves all of these possible events, any of those events might be the one that changes the evaluation outcome from false to true. If that happens, Rule Machine will turn on the electric blanket. Rule Machine only acts on the change of state from false to true, or true to false. It may evaluate the rule many times, depending on what sort of events are subscribed to, but only a truth change causes action. The evaluation of a rule is strictly from left to right. If at any point in the evaluation, the truth value preceding an ANDoperator is false, the rule is false without any further evaluation. Similarly, if the truth value preceding an ORoperator is true, the rule is true without any further evaluation. You must take this into consideration as you define your rule.ActionsWhen the rule proves true, after previously false, Rule Machine will do the actions selected on the Actions for True page. When the rule proves false, after previously true, Rule Machine will do the actions on the Actions for False page. The actions supported are the following: Switches to turn onSwitches to turn offSwitches to turn on/off after a delaySwitches to turn on/off after a delay, pending cancellation from rule state reversalDimmers to level ADimmers to level BLocks to lockLocks to unlockValves to openValves to closeThermostats to setChange modeRun RoutineSend messageDelay the rule taking effect Link to post Share on other sites
Dave 435 Posted November 21, 2015 Author Share Posted November 21, 2015 There is a small section where smartapp discussions are. It would be nice if you could make popular topics like Rule Machine, or even give all Community Based Smart Apps their own section in which to manage posts. Even give them mod rights to their section. But I'm a forums guy and that's a forums thing. Here is a better link: https://community.smartthings.com/c/projects-stories/created-smart-apps Link to post Share on other sites
schoondoggy 900 Posted November 21, 2015 Share Posted November 21, 2015 I had been patiently waiting for the release of Rule Machine. I don't want to build this up too much, but this might fulfill some of the automations I have wanted to do. Link to post Share on other sites
JimBo1489090435 0 Posted November 22, 2015 Share Posted November 22, 2015 This is why I use the ISY, if others did true full automation that would have me consider it. Sent from my Nexus 7 using Tapatalk Link to post Share on other sites
cscompton 9 Posted November 23, 2015 Share Posted November 23, 2015 I played with it this weekend and setup an Alexa control for my Christmas lights. I needs a few more features, like being able to control hue color, but it works really well. I've commented on the Smarttthings forum post about it. Link to post Share on other sites
