Dave 435 Posted March 13, 2015 Share Posted March 13, 2015 I've been waiting for this app for a while now and it's finally approved and in the iOS app store. If you have a SmartThings hub your will want to take a look. https://itunes.apple.com/us/app/smartrules/id957383131?ls=1&mt=8 There is also a "lite" version for you to try. https://itunes.apple.com/us/app/smartrules-lite/id965760672?ls=1&mt=8 Link to post Share on other sites
Dave 435 Posted March 14, 2015 Author Share Posted March 14, 2015 I tested a rul tonight and got mixed results. I made a rule for a phone arriving at home. Check a lamp module and if that module is off turn on a different light switch. Just testing. It worked perfectly. The light that was turned on also has some ST logic though. It's supposed to turn off after 3 minutes of no motion. That never happened. Regardless, I like being able to put multiple pieces of logic in play in order to make things happen. Now, just need the dev to use this forum as a support mechanism. Link to post Share on other sites
