ecobee Smart Si
AwesomeSpaceMonkey
My power utility (SDG&E in San Diego, CA) is giving away the ecobee Smart Si programable thermostat if you agree to participate in their energy saving efforts. Usually it's when we have really hot days and they want to raise your thermostat temp a bit to make sure your AC isn't running too much. Besides the thermostat you also get a discounted rate for that day. Anyways, I've got the thermostat. They installed and set it up in less than 30min. I don't have any other home automation equipment to control it with but there is a WIndows Phone app (ecobee remote). It's from a third party but it works perfectly and the developer is very responsive. There isn't too much to say about it other than it works well, is easy to program, and can be operated from a phone. Another nice feature is that it can show whole home power usage because it's connected to the smart power meter outside. If anyone has any questions I'll do my best to answer.
Peter
http://shop.ecobee.com/products/smart-si
