Surface Pro 4 Finer Control In Battery Saver Mode
thewatergate
Does any one know how to better control your Surface Pro 4 when on the internal battery.  There does not appear to be fine controls, in the control panel.  For example, I love Windows Hello, but I would rather type my password and conserve my battery.  There are many other examples of conserving my battery.  Any thoughts?
if I need maximum battery life I run it on battery saver mode and turn brightness down to the lowest level that I can stand, I also try not to use the backlit keyboard. If Im doing ultra light tasks I tweak the profile to only allow the processor to hit 50-75% max performance and I NEVER use connected standby or sleep modes ever...the surface boots fast enough that you aren't waiting long before the log on screen pops up...if I don't need wifi I turn that off also.
Don't forget to turn off Bluetooth if you're not using it
Sent from my iPad using Tapatalk
