Disappointed - Surface Pro 4 Pen Does Not Transmit Angle Data
jzucker
Got an I5 8GB, 256SSD surface pro 4 today. Very happy to report that it can handle a 4000x6000 image with 10 layers with no issues. However, I discovered that the pen does not transmit angle data to photoshop's brush engine. This is a rudimentary feature of the Wacom intuos tablet that allows for natural brush rendering. With the wamcom, the brush engine interprets the angle of the pen just like it would a real brush so for example as you press down harder and at an angle, the brush's bristles compress out and leave a very natural trail just as if you did this with a real brush. Or with a pencil tool, angling the pen allows you to shade an image as if you were drawing with the side of a pencil tip.
You can control the brush angle manually but it's extremely cumbersome to do compared to just angling the brush and it's akin to trying to draw using the mouse. So basically, the pen in the surface pro 4 acts like a mouse that can sense pressure. Without the angle characteristics that even the inexpensive drawing tablets support, i'm not sure the features of the surface pro 4 are enough to warrant using it over a laptop with a tablet.
Does anyone know if the capability to transmit angle data exists in the pen and will it ever be supported? Because if not, I'll probably just go back to using my notebook computer and the wacom tablet.
yes it can. but you have to buy the nib pack, which is about $10. one of the nibs is angled and it works fine. the pack comes with four nibs. hope this helps.
no it can't. Try to draw a figure 8 where the brush strokes and angles are constantly changing as you tilt the pen in different directions as your draw. A fixed angled nib doesn't help. Also, if i want to quickly shade in something with the edge of a pen or do some brush strokes in a different direction based on pen angle, it's not going to help if I have to suddenly stop and change the nib.
