Surface Pro 4 I5 V I7 8Gb V 16Gb
thewatergate
What is the difference in battery life between an i5 and an i7 each with 16Gb Dram?  Also what is the difference in battery life between an i5 with 8Gb and one with 16Gb?  Any test results?
I personally don't think your going to see a huge difference, unless you are pushing the processors to max full time then probably the I-5 comes out with maybe 20 min more battery life. I think the I-5 is the best bang for the buck this time around. If you need more power than what the I-5 provides then probably a laptop is more to your needs.
Likewise, you could look up the power consumption of a 8GB low voltage ddr4 sodimm. These numbers would give you a rough comparison.
