Wifi Woes
chrisoldroyd
Hey Guys, need some help, just picked up a Surface 3 and it is suffering with awful 5ghz WiFi speeds. It came with windows 10 already installed and I have done all the updates available but nothing improves it.
I have an Asus router A66U I think and I get 12mb/s on the 2.4 band and 500kb/s on the 5ghz band. I have used the network on my Surface Pro and that works fine so its an issue with the Surface 3. I have checked for a router firmware update but its up to date.
Anyone any ideas!
Chris
have you compared your adaptor settings to that of the Pro? Maybe there's a setting that is misaligned?
Edited by WolfJT
I have compared and do not see any differences that jump out. It is very strange, File transfer from my server is as follows:-
Asus Router RT-N66U Router connected to 2.4GHz Wifi
File Transfer Surface Pro 9mbps
File Transfer Surface 3 11mbps
Asus Router RT-N66U Router connected to 5GHz Wifi
File Transfer Surface Pro 14mbps
File Transfer Surface 3 487kbps
Not sure what to do as I need to be able to use the 5Ghz with my Surface 3
Chris
Edited by ChrisOldroyd
