brad0war
Hello, I've spent the last few nights trying to get the stylus to work with Flash cs6. The software loads and seems to work fine until I touch the stylus to the canvas/ work space, it draws a single dot and then the cursor freezes in place. I can still select menus and other tools, after a second or two and then what ever the last tool i was using draws a streak towards the tool I'm currently selecting. No problems Photoshop etc., its just Flash.
I've tried uninstalling the Wintab drivers and it made no difference and as far as I can tell everything is up to date.
Any ideas? Is there an extension that would get it to work? Can I pair another stylus to the tablet and work around it that way?
Flash has been really buggy on the Surface Pro and since CS6 is now many years old, I think you may be out of luck.
meh, I'm sure I'll figure something out. I'll report back with any new changes etc.
    • Joe_Miner
      By Joe_Miner
      By: JohnStutsman
      Figure 1 – HPE ProLiant ML30 Gen9 on static mat ready for Windows 10 pro x64 install via iLO4
      Figure 2 – This shows my Samsung 840 Pro (This will be my OS drive) set up in a single drive RAID0 in the B140i using SSA
      After manually installing Windows Server 2016 easily on HPE’s ProLiant ML30 Gen9 I was anxious to see if an install of Window 10 Pro would be just as trouble free. It was!
      Besides having Hyper-V capabilities, Windows 10 Pro, is being looked on by many as the basis of a low cost Home Server as illustrated in “Building a Windows 10 Home Server – Anniversary Update Edition”. Check out HPE’s Operating System Support Matrices for insights on the many OS’s that the ML30 Gen9 supports. But, what will work goes beyond what’s officially supported by HPE in the “Matrices”. Windows 10 Pro is not listed in the Matrices but Windows Server 2016 is and Server 2016 shares much of the code with Windows 10 Pro as does Server 2012R2 shares with Windows 8.1 pro and Server 2012 shares with Windows 8. In order to manually load Windows 10 Pro I downloaded drivers for Server 2016. The simplest procedure, for me, is to use SPP to update all the ML30 Gen9 firmware first, then use the drivers for the B140i to load Windows 10 Pro, then after Windows 10 Pro is loaded and updated use HPSUM to load all the relevant drivers and software into Windows 10 Pro.
      Like Server 2016, Windows 10 Pro has its own generic drivers that will work with the ML30 Gen9’s NIC and Video so the B140i drivers is all that’s needed to get Windows 10 Pro onto the ML30 Gen9! HPSUM run (with Administrator Privileges) will load all of the missing HPE drivers I need in one step – including the NIC’s, Video, and SSA – just to name a few.
      Step-By-Step: Windows 10 Pro on HPE ProLiant ML30 Gen9
      I used iLO4 to remote into the ML30 Gen9 and began to install Windows 10 Pro x64 manually (i.e. without using IP) in the following general steps:
      Since I had just recently done steps 1-7 not long ago I skipped to 5 then did 7 through 16 below.
      Download Service Pack for ProLiant (SPP) from Hewlett Packard Enterprise Support Center – Drivers & Software – the current version is 2016.10.0 (24 Oct 2016) – check also threads about SPP at HSS Forum MS Gen8 Load the SPP ISO in “virtual drives” in remote desktop of iLO4 Boot the ML30 Gen9 – with no drives in the ML30 Gen9 in my case – and let SPP run automatically and update all firmware – See Figure 3 below. Shut down the ML30 Gen9 Next: I removed the Samsung 840 Pro 256GB that I had loaded Server 2016 on (giving me the flexibility to switch OS’s by switching SSD’s in the ML30 Gen9) and loaded another Samsung 840 Pro 256GB into drive 1 of the Icy Dock ToughArmor MB994SP-4SB-1 Go to the Hewlett Packard Enterprise Support Center – Drivers & Software – and download the file cp028631.exe that is the Dynamic Smart Array B140i Controller Driver for 64-bit Microsoft Windows Server 2012/2016 Editions (Since Windows 10 has the same core as Server 2016 I plan to use it for manual installation of Windows 10 64-bit Pro in the ML30 Gen9 – the HPE Drivers & Software site does not have Drivers & Software for non-server OS’s) – the current version is 62.12.0.64 (24 Oct 2016) Extract the files in cp028631.exe and load those into a file folder that I then attach/load in “virtual drives” of remote desktop of iLO4 (during Windows install this will be the folder I browse to so that Windows 10 can pull in the driver and see the Samsung 840 Pro ) Load the Windows 10 Pro x64 ISO in “virtual drives” of remote desktop of iLO4 Boot the ML30 Gen9 During boot go into IP (press F10) and select SSA (Smart Storage Administrator) In SSA I set up the Samsung 840 Pro as a single drive RAID0 to be used as my OS drive – See Figure 2 earlier. Exit SSA & IP and Restart the ML30 Gen9 Proceed with the normal Windows 10 Pro x64 install – During install Windows 10 will ask for location of drivers so it can see the drive(s) – in browse lead it to the location to the file folder of B140i driver(s) in the “virtual drives” C: -- if your OS drive had been previously formatted as MBR you will have to delete that so it can be formatted as GPT. See Video 1 below. After Windows 10 is installed and updated – reattach SPP ISO in remote desktop of iLO4 In the Windows desktop go to the SPP ISO in File Explorer and Execute the Batch file for HPSUM (i.e. execute: launch_hpsum.bat as Administrator) – I chose “Localhost Guided Update” – Automatic Mode After running HPSUM (and rebooting) the HPE software shown in Figure 4 below was installed. Enjoy!
      Figure 3 – After running SPP’s ISO the firmware of the ML30 Gen9 is up to date.
      Video 1 – Browsing to select the file folder with B14i S2016 drivers during install of Windows 10 Pro on HPE ProLiant ML30 Gen9
      Figure 4 – Software installed by HPSUM in Windows Server 2016
      Figure 5 – Temperatures in the ML30 Gen9 via iLO4. BIOS is set on optimal cooling and my single System Fan is running at 6% and the two 40mm fans on the MB994SP-4SB-1 are turned on.
      Figure 6 – System information showing Windows 10 Pro as the OS
      Figure 7 – Basic information showing Windows Server loaded onto my HPE ProLiant ML30 Gen9 running from a single SSD RAID0 in bay 1 of the Icy Dock ToughArmor MB994SP-4SB-1
      All in all Windows 10 Pro was easy to load onto the HPE ProLiant ML30 Gen9 providing a relatively cheaper platform (compared to Windows Server 2016) for a home lab for setting up and testing applications in Hyper-V for instance.
      In the As-Built that follows I list how this ML10v2 is loaded. Be sure to check out more on this at ML10 and ML10v2 Forum and Windows 10 Pro on HPE ProLiant ML30 Gen9 Forum Thread.
      As-Built (I named my Computer: Serenity)
      HPE ProLiant ML30 Gen9 (Product No. 830893) Xeon E3-1240v5 (SkyLake LGA 1151) 8GB ECC RAM (Expandable to 64GB) OS: Windows 10 Pro B140i Dynamic Smart Array: Ports 1-4: (4*3.5” Drive Tray Caddies for Main Drive-Cage Assembly Bays 1-4) B140i Dynamic Smart Array: Ports 5-6: Icy Dock MB994SP-4SB-1 in Top 5.25” half-height Bay; with/ 2*18” SATA III (6 Gb/s) cables attached to Bays 1 & 2 (Bays 3 & 4 are available for future); Molex to Molex & Fan Y-Connector Cable; Samsung 840 Pro 256GB in Bay 1;
      Please join us in the HomeServerShow Forums to discuss this and tell us what you are building at home.
      References:
      Check HSS Forum Post: Other HSS ML30 Blog Postings: http://homeservershow.com/tag/ML30
       HSS HP ProLiant ML30 Forum postings (In HSS Forum ML10 & ML10v2): http://homeservershow.com/forums/index.php?/forum/98-ml10-and-ml10v2/
      HP MicroServer Gen8 – Service Pack for ProLiant – 24th Oct 2016 http://homeservershow.com/forums/index.php?/topic/12034-hp-microserver-gen8-service-pack-for-proliant-24th-oct-2016/
       iLO Advanced License Keys http://homeservershow.com/forums/index.php?/topic/9511-ilo-advanced-license-keys-1850-2400/
       Icy Dock “ToughArmor” MB994SP-4SB-1 http://www.icydock.com/goods.php?id=142
      Scsi4me.com 3.5” Drive Tray Caddy 4 HP ProLiant ML350e ML310e SL250s Gen8 Gen9 G9 651314-001 http://www.ebay.com/itm/231001449171
       HPE ProLiant ML30 Gen9 Server QuickSpecs http://h20195.www2.hp.com/v2/GetDocument.aspx?docname=c04834998&doctype=quickspecs&doclang=EN_US&searchquery=&cc=us&lc=en
      HPE ProLiant ML30 Gen9 Server “Maintenance and Service Guide”; Part Number: 825545-002; November 2016; Edition: 2 => http://h20565.www2.hpe.com/hpsc/doc/public/display?sp4ts.oid=1008556812&docLocale=en_US&docId=emr_na-c04905980 Or go to => http://h20565.www2.hpe.com/portal/site/hpsc/public/psi/home/?sp4ts.oid=1008556812&ac.admitted=1489520211680.125225703.1851288163#manuals
       Check out my HPE ML30 Gen9 Play-List:
    • Joe_Miner
      By Joe_Miner
      By: JohnStutsman
      Figure 1 – Preparing to install new 64GB of RAM
      I upgrade the stock 8GB to 64GB of RAM in the HPE ProLiant ML30 Gen9 using 4 DIMMs (“Sticks”) of Kingston KVR21E15D8/16.
      Figure 2 – Kingston KVR21E15D8/16
      Figure 3 – 64GB RAM about to be installed in HPE ProLiant ML30 Gen9
      Figure 4 – HPE ProLiant ML30 Gen9 – System Board Components & Memory “Type” requirement from “QuickSpecs” – DIMMs removal & installation instructions from “Maintenance & Service Guide” (see links in References below)
      Figure 5 – HPE ProLiant ML30 Gen9 – Memory & DDR4 memory population guidelines from “QuickSpecs” (see links in References below)
      I upgraded to 64GB of RAM in my HPE ProLiant ML30 Gen9 using Kingston KVR21E15D8/16 from Newegg. The KVR21E15D8/16 was suggested by Schoondoggy on the forum thread RAM for ML30 Gen9.
      Video 1 – 64GB RAM in HPE ProLiant ML30 Gen9.
      Figure 6 – View of the four new DIMMs installed for 64GB of RAM. Time to replace the air baffle, tower bezel, and side panel then hook up the ML30 Gen9 and see if it works!
      Figure 7 – IT WORKS! Screen during first post showing 64GB RAM - for the first time!  Thank you Schoondoggy!!
      Figure 8 – System Summary Information showing 64GB RAM installed
      Figure 9 – System Information with Installed Physical Memory (64GB RAM) Highlighted
      Figure 10 – Task Manager showing 64GB of DDR4.
      Figure 11 – iLO4 System Information – Memory Information showing four 16GB DIMMs installed.  Status is "Good, In Use".
      Figure 12 – Temperatures appear well within range while system fan speed was a consistent 6% - BIOS set to Optimal Cooling (Note that the two 40mm fans in the Icy Dock ToughArmor MB994SP-4SB-1 were also running).
      Figure 13 – HPE ProLiant ML30 Gen9 running with 64GB RAM and using 30.1 Watts. Everything seems to be working well – time to think about adding more drives and turn on Hyper-V!!
      HPE ProLiant ML30 Gen9 (Product No. 830893) Xeon E3-1240v5 (SkyLake LGA 1151) 64GB ECC RAM – Kingston KVR21E15D8/16 OS: Windows 10 Pro B140i Dynamic Smart Array: Ports 1-4: (4*3.5” Drive Tray Caddies for Main Drive-Cage Assembly Bays 1-4) B140i Dynamic Smart Array: Ports 5-6: Icy Dock MB994SP-4SB-1 in Top 5.25” half-height Bay; with/ 2*18” SATA III (6 Gb/s) cables attached to Bays 1 & 2 (Bays 3 & 4 are available for future); Molex to Molex & Fan Y-Connector Cable; Samsung 840 Pro 256GB in Bay 1;
      Reference:
      RAM for ML30 Gen9 http://homeservershow.com/forums/index.php?/topic/14807-ram-for-ml30-gen9/
      ValueRAM Decoder https://www.kingston.com/us/memory/valueram/valueram_decoder
      ValueRAM KVR21E15D8/16 Specs Sheet http://www.kingston.com/dataSheets/KVR21E15D8_16.pdf
      HomeServerShow Forum for ML10’s & ML30’s http://homeservershow.com/forums/index.php?/forum/98-ml10-and-ml10v2/
      HPE ProLiant ML30 Gen9 Server Maintenance & Service Guide http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c04905980-1.pdf
    • tim823
      By tim823
      I have a Lenovo Thinkpad Yoga, and everything works fine with my pen(the pen that comes with, and a random extra pen I bought), but I just installed Adobe Flash for work, and whenever I try to draw with the brush or pencil, It immediatly makes a big diagonal line, then offsets my drawing input to the end of that line. Its something that makes it completely impossible to use. I checked all the settings, and there doesnt seem to be much for pen input. I am also using the720-4 Wacom Feel it driver, which I think is the most recent. If anyone has any solution as to what I can do to rectify this, I would greatly appreciate it!
      Again, its only when I draw in Flash, it is acurate and matches up even when just using other tools in Flash, and draws just fine in Photoshop.
      The pic I attached is me trying to draw a circle in the middle of the page. You can see the line, and then how it offset it,
    • EricTheRed1488993265
      By EricTheRed1488993265
      Having worked with both the Surface RT and an Acer Iconia W7, I think that the reference MS hardware is still the better design. That said, I really like the Iconia running the core i5.
      -Eric
    • Dave
      By Dave
      I thought I would pose a question to you guys.  What anti-virus / anti-spyware package are you running on your Surface Pro?
      Sticking with Windows Defender?
      Running something with a little more Oomph?
