Unable To Charge When Usb Plugged Into The Port On Charger
shugs81
Hi guys
Tonight for some unknown reason when i plugged a working usb cable into the port on the charger it refused to charge either the phone or the surface pro 3. imamabout to try a different usb cable but just wondering if it doesnt work how would i go about replacing the charger? ive only had the pro for 4days!!!
Thanks peep
If you have not done this already, unplug the charger and wait a few minutes.  Then try it again.  I have a USB charger that has self protection on the ports and it will disable a port if it detects a problem. It's possible this is occurring here too.  Also, try a different cable.  That one may have a short.
Panic over!! I used my new fancy high speed usb cable again and it seems fine now... the other cable still works with a different charger which is why I was worried!! That'll teach me to be lazy! But cheers for the advice though... that's something I'd not thought about and if it happens in the future I know what to try!
Sent from my Passport using Tapatalk
