Bitlocker On Surface 3
HiramSS
I was tweaking my Surface 3 a couple of days ago.  Wanted to do some in System Configuration (msconfig), but got a message about Bitlocker Encryption.
What is this about and how can I get around it?
Thanks.
Picture attached
Since upgrading my Surface 3 to W10, it has been a bit laggy, slow in loading some windows, apps, browsers.  I googled about this and a few reputable sources suggested that in Boot/Advanced Options I check the Number of Processors and the Maximum Memory.  Also, to lower the Timeout to 3 seconds.  I was going to try, when I got the Encryption warning.
What timeout is that you are changing? I can't see why Bitlocker would worry about that. You may want to try to suspend Bitlocker protection and then try to change the setting then enable Bitlocker after.
go to control panel/system and security/bitlocker drive encryption: there you'll see the option to suspend protection.
thanks for your help Wolf. But there is no System and Security in Control panel.
I searched all through System, then Security and Maintenance, and found nothing for Bitlocker.
I searched Bitlocker and got two entries in the suggestions: Manage Bitlocker (control panel) and
Change device encryption settings (System Settings). When I click either, I get "No results for Bitlocker in the results.
Am I missing something or is this strange?
Sorry Wolf. Major blooper. When I wrote my last post, saying I couldn't find anything, I was actually using my laptop, which I presume doesn't have encryption.  I totally overlooked that fact when I read your most reason response. The PC I had been talking about in my OP is my Surface 3, from which I'm writing.  When I type Bitlocker in Cortana, I'm taken to Settings/Systems/About.  At the bottom, there's a heading that says Device Encryption, and under that On, with a button to Turn Off.
So, having said this, and imposed on you enough, if I turn it off, will it be in effect disabled (temporarily)? ... and will the Turn Off button become a Turn On button so that I can enable again?
Thanks.
I would say yes it would disable it if you turn it off. I would say yes it "should" be turn into a turn on button. But I've not tried it.....
