mhdizzy Posted July 13, 2015 Share Posted July 13, 2015 Hi i have a micro sd card in my s3 but it goes offline sometimes and i have to remove it then reinsert it for it to come back online. it is nfts formatted. has anyone else had this issue? Link to comment Share on other sites More sharing options...
schoondoggy Posted July 14, 2015 Share Posted July 14, 2015 What is the type or part number of the card? Link to comment Share on other sites More sharing options...
mhdizzy Posted July 14, 2015 Author Share Posted July 14, 2015 i think its a sandisc i put a piece of black electrical tape on the backside of the card,it seems to have fixed the problem so far,fingers crossed... Link to comment Share on other sites More sharing options...
schoondoggy Posted July 14, 2015 Share Posted July 14, 2015 Some cards do not support NTFS format. Link to comment Share on other sites More sharing options...
WolfJT Posted July 15, 2015 Share Posted July 15, 2015 I am seeing the same thing with the SP3. I havea Sandisk 64 gig card. I did not see this issue with a 32 gig card. What is the size of your card? Link to comment Share on other sites More sharing options...
schoondoggy Posted July 15, 2015 Share Posted July 15, 2015 I am seeing the same thing with the SP3. I havea Sandisk 64 gig card. I did not see this issue with a 32 gig card. What is the size of your card? Is your card micro SDHC or SDXC? Link to comment Share on other sites More sharing options...
WolfJT Posted July 15, 2015 Share Posted July 15, 2015 XC sent from TapTalk for Windows Phone Link to comment Share on other sites More sharing options...
schoondoggy Posted July 15, 2015 Share Posted July 15, 2015 It is highly recommended to format them with this: https://www.sdcard.org/downloads/formatter_4/index.html Link to comment Share on other sites More sharing options...
DLCPhoto Posted July 15, 2015 Share Posted July 15, 2015 (edited) This is a known problem for various Surface devices, and I've seen reports involving a wide variety of brands and sizes. I've been unable to pinpoint what the specific problem is. In my case, I had a Lexar 633x 128gb card, UHS-I/U3, 95 MBps, which seemed to be the fast I could find, that kept unmounting under certain circumstances (connecting a USB hard drive, flash drive, etc.). I replaced it with a SanDisk Ultra 128gb (48 MBps), which has performed flawlessly. Edited July 15, 2015 by DLCPhoto 1 Link to comment Share on other sites More sharing options...
WolfJT Posted July 15, 2015 Share Posted July 15, 2015 I'll give this a try. Thanks Link to comment Share on other sites More sharing options...
