Newbie Questions. Need Help!
HiramSS
I just upgraded from my Surface RT, which for three years has served me well, to the Surface 3. (64G model).  After four days, I’m loving it, but have some initial newbie questions.
  1.  The RAM usage is consistently at 40-70% of the 2G.  Is this normal?
  1. When I share (Charm Bar) a web page or other via email, it does not reach my gmail or aol accounts, but shows up on my Outlook account (Lumia 825), with a message as follows:
 postmaster@mail.hotmail
Delivery Status Notification (Failure)
This is an automatically generated Delivery Status Notification.
Delivery to the following recipient failed.
            Is there something that I need to do?
  1. I have yet to purchase the Surface pen.  Is this the only way to right on the Surface? And if I buy it, other than using it on writing and painting apps, can I use it to draw or annotate on a PDF document or PowerPoint slide being shown on the Surface?
Looking forward to prompt replies. The trial period clock is ticking.
